A diskette that contains a JumpStart directory is called a profile diskette. A system that is not connected to the network does not have access to a profile server. As a result, you must create a JumpStart directory on a diskette if a system is not connected to a network. The system on which you create a profile diskette must have a diskette drive.
The JumpStart directory contains all of the essential custom JumpStart files, for example, the rules file, rules.ok file, and profiles. You must save the JumpStart directory in the root (/) directory of the profile diskette.
This procedure assumes that the system is running Volume Manager. If you are not using Volume Manager to manage diskettes, CDs, and DVDs, refer to System Administration Guide: Devices and File Systems for detailed information about managing removable media without Volume Manager.
Log in as superuser on a SPARC system to which a diskette drive is attached.
Insert a blank diskette or a diskette that can be overwritten in the diskette drive.
# volcheck |
Determine if the diskette contains a UNIX file system (UFS).
Examine the contents of the file /etc/mnttab on the system for an entry such as the following:
/vol/dev/diskette0/scrap /floppy/scrap ufs suid,rw,largefiles,dev=1740008 927147040 |
If the entry exists, go to Step 7.
If the entry does not exist, go to the next step.
Formatting erases all data on the diskette.
# fdformat -U |
# newfs /vol/dev/aliases/floppy0 |
Determine if you want to copy examples of custom JumpStart files to your JumpStart directory.
If no, go to Step 10.
If yes, use the following decision table to determine what to do next.
Copy the example custom JumpStart files into the JumpStart directory on the profile diskette.
# cp -r media_path/Solaris_9/Misc/jumpstart_sample/* jumpstart_dir_path |
The path to the CD, DVD, or image on the local disk
The path to the profile diskette where you want to place the example custom JumpStart files
You must place all custom JumpStart installation files in the root (/) directory on the diskette.
For example, the following command copies the contents of jumpstart_sample on the Solaris Software 1 of 2 SPARC Platform Edition CD to the root (/) directory on a profile diskette that is named scrap:
cp -r /cdrom/sol_9_sparc/s0/Solaris_9/Misc/jumpstart_sample/* /floppy/scrap |
Update the example JumpStart files on the profile diskette so that the files work in your environment.
Ensure that root owns the JumpStart directory and that permissions are set to 755.
Eject the diskette.
# eject floppy |
You have completed the creation of a profile diskette. You can now update the rules file and create profiles on the profile diskette to perform custom JumpStart installations. To continue, go to Creating the rules File.
Log in as superuser on an x86 system to which a diskette drive is attached.
Insert the Solaris Device Configuration Assistant x86 Platform Edition diskette into the diskette drive (usually drive A). You use this diskette as the profile diskette.
You can copy the Device Configuration Assistant software to a diskette from the Solaris x86 Platform Edition DVD or Solaris Software 2 of 2 x86 Platform Edition CD by using the procedure in Appendix I, x86: Preparing to Boot From the Solaris Device Configuration Assistant or the Network (Tasks).
# volcheck |
Copy the image of the Solaris Device Configuration Assistant to the system's hard disk.
# dd if=/vol/dev/aliases/floppy0 of=boot_image |
In the command, boot_image is the name of the file into which you want to copy the image of the Solaris Device Configuration Assistant. You can specify an absolute path name.
For example, the following command copies the boot diskette to a file that is named boot_save:
dd if=/vol/dev/aliases/floppy0 of=boot_save |
Eject the diskette by clicking Eject Disk in the File Manager window or by typing eject floppy on the command line.
In the Removable Media Manager dialog box, click OK.
Manually eject the Solaris Device Configuration Assistant x86 Platform Edition diskette.
Insert a blank diskette or a diskette that can be overwritten into the diskette drive.
# volcheck |
# fdformat -d -U |
Copy the Solaris Device Configuration Assistant image from the system's hard disk to the formatted diskette.
# dd if=boot_image of=/vol/dev/aliases/floppy0 |
In the command, boot_image is the name of the file where you want to copy the image of the Solaris Device Configuration Assistant. You can specify an absolute path name.
If no, go to Step 15.
Example Locations |
Instructions |
The Solaris x86 Platform Edition DVD or the Solaris Software 1 of 2 x86 Platform Edition CD |
Insert the Solaris x86 Platform Edition DVD or the Solaris Software 1 of 2 x86 Platform Edition CD into the server's CD-ROM drive. Volume Manager automatically mounts the CD. |
An image of the Solaris x86 Platform Edition DVD or the Solaris Software 1 of 2 x86 Platform Edition CD on a local disk |
Change directory to the location of the Solaris x86 Platform Edition DVD or the Solaris Software 1 of 2 x86 Platform Edition CD image. For example, type the following:
You must place all custom JumpStart installation files in the root (/) directory on the profile diskette.
For example, the following command copies the contents of jumpstart_sample on the Solaris Software 1 of 2 x86 Platform Edition CD to the root (/) directory on a profile diskette that is named scrap:
cp -r /cdrom/sol_9_x86/s2/Solaris_9/Misc/jumpstart_sample/* /floppy/scrap |
Manually eject the diskette.
You have completed the creation of a profile diskette. Now you can update the rules file and create profiles on the profile diskette to perform custom JumpStart installations. To continue, go to Creating the rules File.
