Solaris 9 9/04 Installation Guide
Rule Keywords and Values
Table 31–1 describes the keywords and values that you can use in the rules file. For detailed instructions to create a rules file, see Creating the rules File.
Table 31–1 Descriptions of Rule Keywords and Values
Keyword
Value
Matches
any
minus sign (-)
Anything. The any keyword always succeeds.
arch
processor_type
Valid values for processor_type are the following:
  • SPARC: sparc
  • x86: i386
A system's processor type.
The uname -p command reports the system's processor type.
disksize
actual_disk_name size_range
actual_disk_name – A disk name in the form cxtydz, such as c0t3d0or c0d0, or the special word rootdisk. If rootdisk is used, the disk to be matched is determined in the following order:
  • SPARC: The disk that contains the preinstalled boot image, which is a new SPARC based system with factory JumpStart installed
  • The c0t3d0s0 disk, if the disk exists
  • The first available disk that is searched in kernel probe order
size_range – The size of the disk, which must be specified as a range of Mbytes (x-x).
The name and size of a system's disk in Mbytes.
Example:
disksize c0t3d0 250-300
In the example, the JumpStart program attempts to match a system disk that is named c0t3d0. The disk can hold between 250 and 300 Mbytes of information.
Example:
disksize rootdisk 750-1000
In the example, the JumpStart program first attempts to match a system disk that contains a preinstalled boot image. Next, the JumpStart program attempts to match the c0t3d0s0 disk, if the disk exists. Finally, the JumpStart program attempts to match the first available disk that can hold between 750 Mbytes and 1 Gbyte of information.
Note –
When calculating size_range, remember that a Mbyte equals 1,048,576 bytes. A disk might be advertised as a “535–Mbyte” disk, but the disk might contain only 510 million bytes of disk space. The JumpStart program views the “535–Mbyte” disk as a 510–Mbyte disk because 535,000,000 / 1,048,576 = 510. A “535–Mbyte” disk does not match a size_range equal to 530–550.
domainname
actual_domain_name
A system's domain name, which controls how a name service determines information.
If you have a system already installed, the domainname command reports the system's domain name.
hostaddress
actual_IP_address
A system's IP address.
hostname
actual_host_name
A system's host name.
If you have a system that is already installed, the uname -n command reports the system's host name.
installed
slice version
slice — A disk slice name in the form cwtxdysz, such as c0t3d0s5, or the special words any or rootdisk. If any is used, the JumpStart program attempts to match all of the system's disks in kernel probe order. If rootdisk is used, the disk to be matched is determined in the following order:
version — A version name or the special words any or upgrade. If any is used, any Solaris or SunOS release is matched. If upgrade is used, any Solaris 2.6 or compatible release that can be upgraded is matched.
If the JumpStart program finds a Solaris release but is unable to determine the version, the version that is returned is SystemV.
A disk that has a root (/) file system that corresponds to a particular version of Solaris software.
Example:
installed c0t3d0s1 Solaris_9
In the example, the JumpStart program attempts to match a system that has a Solaris 9 root (/) file system on c0t3d0s1.
karch
actual_platform_group
Valid values are sun4m, sun4u, i86pc, prep. A list of systems and their corresponding platform group is presented in the Solaris 9 Sun Hardware Platform Guide.
A system's platform group.
If you have a system that is already installed, the arch -k command or the uname -m command reports the system's platform group.
memsize
physical_mem
The value must be a range of Mbytes, x-x, or a single Mbyte value.
A system's physical memory size in Mbytes.
Example:
memsize 64-128
The example tries to match a system with a physical memory size between 64 and 128 Mbytes.
If you have a system that is already installed, the output of the prtconf command, line 2, reports the system's physical memory size.
model
actual_platform_name
A system's platform name. See the Solaris 9 Sun Hardware Platform Guide for a list of valid platform names.
To find the platform name of an installed system, use the uname -i command or the output of the prtconf command, line 5.
Note –
If the actual_platform_name contains spaces, you must replace spaces with underscores (_).
Example:
SUNW,Sun_4_50
network
network_num
A system's network number, which the JumpStart program determines by performing a logical AND between the system's IP address and the subnet mask.
Example:
network 193.144.2.8
The example tries to match a system with a 193.144.2.8 IP address, if the subnet mask is 255.255.255.0.
osname
Solaris_x
A version of Solaris software that is already installed on a system.
Example:
osname Solaris_9
In the example, the JumpStart program attempts to match a system with the Solaris 9 operating environment already installed.
probe
probe_keyword
A valid probe keyword or a valid custom probe keyword.
Example:
probe disks
The example returns the size of a system's disks in Mbytes and in kernel probe order, for example, c0t3d0s1, c0t4d0s0, on a SPARC system. The JumpStart program sets the SI_DISKLIST, SI_DISKSIZES, SI_NUMDISKS, and SI_TOTALDISK environment variables.
Note –
The probe keyword is unique in that the keyword does not attempt to match an attribute and run a profile. The probe keyword returns a value. Consequently, you cannot specify begin scripts, profiles, and finish scripts with the probe rule keyword.
Probe keywords are described in Chapter 28, Creating Custom Rule and Probe Keywords (Tasks).
totaldisk
size_range
The value must be specified as a range of Mbytes (x-x).
The total disk space on a system in Mbytes. The total disk space includes all the operational disks that are attached to a system.
Example:
totaldisk 300-500
In the example, the JumpStart program tries to match a system with a total disk space between 300 and 500 Mbytes.
Note –
When calculating size_range, remember that one Mbyte equals 1,048,576 bytes. A disk might be advertised as a “535–Mbyte” disk, but the disk might have only 510 million bytes of disk space. The JumpStart program views the “535–Mbyte” disk as a 510–Mbyte disk because 535,000,000 / 1,048,576 = 510. A “535–Mbyte” disk does not match a size_range equal to 530–550.
