Solaris 9 9/04 Installation Guide
Initial Installation of the Solaris 9 Operating Environment
Initial installation fails
Solution:
If the Solaris installation fails, you must restart the installation. To restart the installation, boot the system from the Solaris DVD, Solaris Installation CD, the Solaris Software 1 of 2, or from the network.
You cannot uninstall the Solaris software after the software has been partially installed. You must restore your system from a backup or begin the Solaris installation process again.
/cdrom/Solaris_9/SUNWxxxx/reloc.cpio: Broken pipe
Description:
This error message does not affect the installation.
Solution:
Ignore the message and continue with the installation.
WARNING: CHANGE DEFAULT BOOT DEVICE (x86 based systems only)
Cause:
This is an informational message. The default boot device set in the system's BIOS might be set to a device that requires you to use the Solaris Device Configuration Assistant x86 Platform Edition diskette to boot the system.
Solution:
Continue with the installation and, if necessary, change the system's default boot device specified in the BIOS after you install the Solaris software to a device that does not require the Solaris Device Configuration Assistant x86 Platform Edition diskette.
x86: To Check IDE Disk for Bad Blocks
IDE disk drives do not automatically map out bad blocks like other drives supported by Solaris software. Before installing Solaris 9 on an IDE disk, you might want to perform a surface analysis on the disk. To perform surface analysis on an IDE disk, follow this procedure.
  1. Boot to the installation media in single-user mode.
     # b -s
  2. Start the format program.
    # format
  3. Specify the IDE disk drive on which you want to perform a surface analysis.
    # cxdy
    cx
    Is the controller number
    dy
    Is the device number
  4. You need an fdisk partition.
    • If a Solaris fdisk partition already exists, proceed to Step 5.
    • If a Solaris fdisk partition does not exist, use the fdisk command to create a Solaris partition on the disk.
    format> fdisk
  5. Type:
    format> analyze
  6. Type:
    analyze> config
    The current settings for a surface analysis are displayed.
    1. If you want to change settings, type:
      analyze> setup
  7. Type:
    analyze> type_of_surface_analysis
    Is read, write, or compare
    If format finds bad blocks, it re-maps them.
  8. Type:
    analyze> quit
  9. Do you want to specify blocks to re-map?
    • If no, go to Step 10.
    • If yes, type:
      format> repair
  10. Type:
    quit
    The format program quits.
  11. To restart the media in multiuser mode, type:
    ok b
