Solaris 9 9/04 Installation Guide
To Continue Upgrading After a Failed Upgrade
The upgrade fails and the system cannot be soft-booted. The failure is for reasons beyond your control, such as a power failure or a network connection failure.
  1. Reboot the system from the Solaris DVD, Solaris Installation CD, the Solaris Software 1 of 2 CD, or from the network.
  2. Choose the upgrade option for installation.
    The Solaris installation program determines if the system has been partially upgraded and continues the upgrade.
