Solaris 9 9/04 Installation Guide
Create the wanboot.conf File
WAN boot uses the configuration information that is included in the wanboot.conf file to install the client machine. Create the wanboot.conf file in a text editor. Save the file to the appropriate client subdirectory in the /etc/netboot hierarchy on the WAN boot server.
The following wanboot.conf file for wanclient-1 includes configuration information for a WAN installation that uses secure HTTP. This file also instructs WAN boot to use a HMAC SHA1 hashing key and a 3DES encryption key to protect data.
boot_file=/wanboot/wanboot.s9_sparc
root_server=https://www.example.com/cgi-bin/wanboot-cgi
root_file=/miniroot/miniroot.s9_sparc
signature_type=sha1
encryption_type=3des
server_authentication=yes
client_authentication=no
resolve_hosts=
boot_logger=
system_conf=sys.conf
This wanboot.conf file specifies the following configuration.
The wanboot program is named wanboot.s9_sparc. This program is located in the wanboot directory in the document root directory on wanserver-1.
The location of the wanboot-cgi program on wanserver-1 is https://www.example.com/cgi-bin/wanboot-cgi. The https portion of the URL indicates that this WAN boot installation uses secure HTTP.
The WAN boot miniroot is named miniroot.s9_sparc. The miniroot is located in the miniroot directory in the document root directory on wanserver-1.
signature_type=sha1
The wanboot program and the WAN boot file system are signed by using a HMAC SHA1 hashing key.
The wanboot program and the WAN boot file system are encrypted with a 3DES key.
The server is authenticated during the installation.
The client is not authenticated during the installation.
Note –
If you performed the tasks in (Optional) Use Private Key and Certificate for Client Authentication, set this parameter as client_authentication=yes
resolve_hosts=
No additional host names are needed to perform the WAN installation. All the host names that are required by the wanboot-cgi program are specified in the wanboot.conf file and the client certificate.
boot_logger=
Booting and installation log messages are displayed on the system console. If you configured the logging server in (Optional) Configure the WAN Boot Server as a Logging Server, and you want WAN boot messages to appear on the WAN boot server as well, set this parameter to boot_logger=https://www.example.com/cgi-bin/bootlog-cgi.
The system configuration file that specifies the locations of the sysid.cfg and JumpStart files is located in the sys.conf file in the /etc/netboot hierarchy on wanserver-1.
In this example, you save the wanboot.conf file in the /etc/netboot/192.168.198.0/010003BA152A42 directory on wanserver-1.
