Solaris 9 9/04 Installation Guide
System Configuration File Settings and Syntax
The system configuration file enables you to direct the WAN boot installation programs to the following files.
The system configuration file is a plain text file, and must be formatted in the following pattern.
setting=value
The system.conf file must contain the following settings.
SsysidCF=sysidcfg-file-URL
This setting points to the directory on the install server that contains the sysidcfg file. For WAN installations that use HTTPS, set the value to a valid HTTPS URL.
SjumpsCF=jumpstart-files-URL
This setting points to the custom JumpStart directory that contains the rules.ok and profile files. For WAN installations that use HTTPS, set the value to a valid HTTPS URL.
You can store the system.conf in any directory that is accessible to the WAN boot server.
