Solaris 9 9/04 Installation Guide
x86: Task Map: Performing a Solaris Web Start Installation
Table 17–2 x86: Performing a Solaris Web Start Installation Task Map
Task
Description
For Instructions
Verify system requirements.
Verify that your system meets the requirements to install or upgrade with the Solaris Web Start program.
Memory Requirements
Gather the necessary information.
Follow the checklist and complete the worksheet to be sure that you have all of the information you need to install the Solaris software.
Chapter 6, Gathering Information Before Installation or Upgrade (Planning)
(Upgrade only) Prepare to upgrade the system.
Back up the system.
System Administration Guide: Devices and File Systems
(Optional) Set up the system to install from the network.
To install a system from a remote Solaris x86 Platform Edition DVD or Solaris Software x86 Platform Edition CD net installation image, you must set up the system to boot and install from an install server or boot server.
Chapter 15, Preparing to Install From the Network With CD Media (Tasks)
Install or upgrade.
Boot the system and follow the prompts to install or upgrade the Solaris software.
x86: To Perform an Installation or Upgrade With the Solaris Web Start Program
(Upgrade only) Perform post-upgrade task.
Correct any local modifications that were lost during the upgrade.
To Correct Local Modifications After Upgrading
