Solaris Volume Manager Administration Guide
ProcedureHow to Check the State of Transactional Volumes
Step
    To check the status of a transactional volume, use one of the following methods:
    • From the Enhanced Storage tool within the Solaris Management Console, open the Volumes node, then view the status of the volumes. Right-click a transactional volume and choose Properties for more detailed status information. For more information, see the online help.
    • Use the metastat command.
      For more information, see the metastat(1M) man page.
Example 19–4 Checking the Status of Transactional Volumes
Here is sample transactional volume output from the metastat command:
# metastat
d20: Trans
    State: Okay
    Master Device: c0t3d0s4
    Logging Device: c0t2d0s3
        Master Device       Start Block  Dbase
        c0t3d0s4                   0     No
c0t2d0s3: Logging device for d0
    State: Okay
        Logging Device      Start Block  Dbase
        c0t2d0s3                 250     No
