Solaris Volume Manager Administration Guide
Solaris Volume Manager Roadmap—Administration
Table 1–5 Solaris Volume Manager Roadmap—Administration
Task
Description
For Instructions
Graphically administer your volume management configuration
Use the SolarisTM Management Console to administer your volume management configuration.
Online help from within Solaris Volume Manager (Enhanced Storage) node of the Solaris Management Console application
Graphically administer slices and file systems
Use the Solaris Management Console graphical user interface to administer your disks and file systems, performing such tasks as partitioning disks and constructing UFS file systems.
Online help from within the Solaris Management Console application
Optimize Solaris Volume Manager
Solaris Volume Manager performance is dependent on a well-designed configuration. Once created, the configuration needs monitoring and tuning.
Solaris Volume Manager Configuration Guidelines
Working with Configuration Files
Plan for future expansion
Because file systems tend to run out of space, you can plan for future growth by putting a file system into a concatenation.
Creating RAID 0 (Concatenation) Volumes
Expanding Storage Space
