Solaris Volume Manager Administration Guide
Working With Submirrors
ProcedureHow to Attach a Submirror
Note –
If you see an error message stating can't attach labeled submirror to an unlabeled mirror, that indicates that you unsuccessfully attempted to attach a RAID 0 volume to a mirror. A labeled volume (submirror) is a volume whose first component starts at cylinder 0, while an unlabeled volume's first component starts at cylinder 1. To prevent the labeled submirror's label from being corrupted, Solaris Volume Manager does not allow labeled submirrors to be attached to unlabeled mirrors.
Steps
  1. Identify the component (concatenation or stripe) to be used as a submirror.
    It must be the same size (or larger) as the existing submirror in the mirror. If you have not yet created a volume to be a submirror, see Creating RAID 0 (Stripe) Volumes or Creating RAID 0 (Concatenation) Volumes.
  2. Make sure that you have root privilege and that you have a current backup of all data.
  3. Use one of the following methods to attach a submirror.
    • From the Enhanced Storage tool within the Solaris Management Console, open the Volumes node, choose the mirror, then choose Action->Properties and click the Submirrors tab. Follow the instructions on screen. For more information, see the online help.
    • Use the metattach mirror submirror command.
      # metattach mirror submirror
    See the metattach(1M) man page for more information.
Example 11–7 Attaching a Submirror
# metastat d30
d30: mirror
    Submirror 0: d60
      State: Okay
# metattach d30 d70
d30: submirror d70 is attached
# metastat d30
d30: mirror
    Submirror 0: d60
      State: Okay
    Submirror 1: d70
      State: Resyncing
    Resync in progress: 41 % done
    Pass: 1
    Read option: roundrobin (default)
    Write option: parallel (default)
This example shows the attaching of a submirror, d70, to a one-way mirror, d30, creating a two-way mirror. The mirror d30 initially consists of submirror d60. The submirror d70 is a RAID 0 volume. You verify that the status of the mirror is “Okay” with the metastat command, then attach the submirror. When the metattach command is run, the new submirror is resynchronized with the existing mirror. When you attach an additional submirror to the mirror, the system displays a message. To verify that the mirror is resynchronizing, use the metastat command.
ProcedureHow to Detach a Submirror
Steps
  1. Make sure that you have root privilege and that you have a current backup of all data.
  2. Read Background Information for RAID 1 Volumes.
  3. Use one of the following methods to detach a submirror.
    • Use the metadetach command to detach a submirror from a mirror.
      # metadetach mirror submirror
      See the metadetach(1M) man page for more information.
Example 11–8 Detaching a Submirror
# metastat
d5: mirror
    Submirror 0: d50
# metadetach d5 d50
d5: submirror d50 is detached
In this example, mirror d5 has a submirror, d50, which is detached with the metadetach command. The underlying slices from d50 are going to be reused elsewhere. When you detach a submirror from a mirror, the system displays a confirmation message.
ProcedureHow to Place a Submirror Offline and Online
The metaonline command can only be used when a submirror was taken offline by the metaoffline command. After the metaonline command runs, Solaris Volume Manager automatically begins resynchronizing the submirror with the mirror.
Note –
The metaoffline command's capabilities are similar to that offered by the metadetach command. However, the metaoffline command does not sever the logical association between the submirror and the mirror.
Steps
  3. Use one of the following methods to place a submirror online or offline.
    • Use the metaoffline command to take offline a submirror.
      # metaoffline mirror submirror
      See the metaoffline(1M) man page for more information.
    • Use the metaonline command to bring a submirror online.
      # metaonline mirror submirror
      See the metaonline(1M) man page for more information.
Example 11–9 Placing a Submirror Offline
# metaoffline d10 d11
d10: submirror d11 is offlined
In this example, submirror d11 is taken offline from mirror d10. Reads will continue to be made from the other submirror. The mirror will be out of sync as soon as the first write is made. This inconsistency is corrected when the offlined submirror is brought back online.
Example 11–10 Placing a Submirror Online
# metaonline d10 d11
d10: submirror d11 is onlined
In this example, submirror d11 is brought back online in mirror d10.
ProcedureHow to Enable a Slice in a Submirror
Steps
  2. Read Overview of Replacing and Enabling Components in RAID 1 and RAID 5 Volumes and Background Information for RAID 1 Volumes.
  3. Use one of the following methods to enable a slice in a submirror.
    • Use the metareplace command to enable a failed slice in a submirror.
      # metareplace -e mirror failed-slice
      The metareplace command automatically starts a resynchronization to synchronize the repaired or replaced slice with the rest of the mirror.
      See the metareplace(1M) man page for more information.
Example 11–11 Enabling a Slice in a Submirror
# metareplace -e d11 c1t4d0s7
d11: device c1t4d0s7 is enabled
In this example, the mirror d11 has a submirror that contains slice, c1t4d0s7, which had a soft error. The metareplace command with the -e option enables the failed slice.
If a physical disk is defective, you can either replace it with another available disk (and its slices) on the system as documented in How to Replace a Slice in a Submirror. Alternatively, you can repair/replace the disk, format it, and run the metareplace command with the -e option as shown in this example.
