Solaris Volume Manager Administration Guide
Solaris Volume Manager Monitoring and Reporting (Task Map)
The following task map identifies the procedures needed to manage Solaris Volume Manager error reporting.
Task
Description
Instructions
Set the mdmonitord daemon to periodically check for errors
Set the error-checking interval used by the mdmonitord daemon by editing the /etc/rc2.d/S95svm.sync file.
Configuring the mdmonitord Command for Periodic Error Checking
Configure the Solaris Volume Manager SNMP agent
Edit the configuration files in the /etc/snmp/conf directory so Solaris Volume Manager will throw traps appropriately, to the correct system.
Configuring the Solaris Volume Manager SNMP Agent
Monitor Solaris Volume Manager with scripts run by the cron command
Create or adapt a script to check for errors, then run the script from the cron command.
Monitoring Solaris Volume Manager With a cron Job
