System types are sometimes defined by how they access the root (/) and /usr file systems, including the swap area. For example, standalone systems and server systems mount these file systems from a local disk, while other clients mount the file systems remotely, relying on servers to provide these services. This table lists some of the characteristics of each system type.
Table 5–1 Characteristics of General System Types
System Type |
Local File Systems |
Local Swap? |
Remote File Systems |
Network Use |
Relative Performance |
Server |
root (/) /usr /home /opt /export/home /export/root |
Yes |
– None – |
High |
High |
Standalone System |
root (/) /usr /export/home |
Yes |
– None – |
Low |
High |
Diskless Client |
– None – |
No |
root (/) swap /usr /home |
High |
Low |
Appliance |
None |
None |
None |
High |
High |
A server system contains the following file systems:
The root (/) and /usr file systems, plus swap space
The /export and /export/home file systems, which support client systems and provide home directories for users
The /opt directory or file system for storing application software
Servers can also contain the following software to support other systems:
Operating system (OS) services for diskless systems systems that run a different release or clients that are a different platform than the server
Solaris CD image software and boot software for networked systems to perform remote installations
JumpStartTM directory for networked systems to perform custom JumpStart installations
A networked standalone system can share information with other systems in the network, but it can continue to function if detached from the network.
A standalone system can function autonomously because it has its own hard disk that contains the root (/), /usr, and /export/home file systems and swap space. The standalone system thus has local access to operating system software, executables, virtual memory space, and user-created files.
A standalone system requires sufficient disk space to hold its necessary file systems.
A non-networked standalone system is a standalone system with all the characteristics listed above, except it is not connected to a network.
A diskless client has no disk and depends on a server for all its software and storage needs. A diskless client remotely mounts its root (/), /usr, and /home file systems from a server.
A diskless client generates significant network traffic due to its continual need to procure operating system software and virtual memory space from across the network. A diskless client cannot operate if it is detached from the network or if its server malfunctions.
For more overview information about diskless clients, see Diskless Client Management Overview.
An appliance, such as the Sun Ray appliance, is an X display device that requires no administration. There is no CPU, fan, disk, and very little memory. An appliance is connected to a Sun display monitor, but the appliance user's desktop session is run on a server and displayed back to the user. The X environment is setup automatically for the user and has the following characteristics:
Relies on a server to access other file systems and software applications
Provides centralized software administration and resource sharing
Contains no permanent data, making it a field-replaceable unit (FRU)
You can determine which system types are appropriate for your environment by comparing each system type based on the following characteristics:
Centralized Administration
Can the system be treated as a field-replaceable unit (FRU)? This means that a broken system can be quickly replaced with a new system without any lengthy backup and restore operations and no loss of system data.
Does the system need to be backed up? Large costs in terms of time and resources can be associated with backing up a large number of desktop systems.
Can the system's data be modified from a central server?
Can the system be installed from a centralized server, quickly and easily, without handling the client system's hardware?
Performance
Does this configuration perform well in desktop usage?
Does the addition of systems on a network affect the performance of other systems already on the network?
Disk Space Usage
How much disk space is required to effectively deploy this configuration?
This table describes how each system type scores in terms of each category. A ranking of 1 is most efficient. A ranking of 4 is least efficient.
Table 5–2 Comparison of System Types
System Type |
Centralized Administration |
Performance |
Disk Usage |
Standalone System |
4 |
1 |
4 |
Diskless Client |
1 |
4 |
1 |
Appliance |
1 |
1 |
1 |
