System Administration Guide: Basic Administration
Managing Diskless Clients (Task Map)
The following table identifies the procedures needed to manage diskless clients.
Task
Description
For Instructions
1. (Optional) Remove existing diskless client support
If you have existing diskless clients that were added with the Solstice AdminSuite product, remove the diskless client support and OS services with the admhostdel and admhostmod commands before installing the Solaris release.
Solstice AdminSuite 2.3 Administration Guide
3. (Optional) Enable Solaris Management Console logging to view diskless client error messages
Choose Log Viewer from the console main window to view diskless client error messages.
Starting the Solaris Management Console
4. Prepare for adding a diskless client
Verify supported releases and identify the platform, mediapath, and cluster (or software group) of each diskless client.
How to Prepare for Adding Diskless Clients
5. Add required OS services to an OS server
Add the OS services for the diskless clients you want to support with the smosservice command. You must identify the platform, media path, and each diskless client platform that you want to support.
How to Add OS Services For Diskless Client Support
6. Add a diskless client
Add diskless client support by specifying all required information with the smdiskless command.
How to Add a Diskless Client
7. Boot the diskless client
Verify that the diskless client support is successfully added by booting the diskless client.
How to Boot a Diskless Client
8. (Optional) Delete diskless client support
Delete support for a diskless client if it is no longer required.
How to Delete Diskless Client Support
9. (Optional) Delete OS services for a diskless client
Delete OS services for a diskless client if they are no longer needed.
How to Delete OS Services for Diskless Clients
10. (Optional) Patch OS services
Add, delete, list, or synchronize patches for diskless client OS services.
How to Add an OS Patch for a Diskless Client
