System Administration Guide: Basic Administration
Chapter 7 Shutting Down and Booting a System (Overview)
This chapter provides guidelines for shutting down and booting a system. The Solaris software environment is designed to run continuously so that electronic mail and network resources are available to users. Occasionally, it is necessary to shut down or reboot a system because of a system configuration change, a scheduled maintenance event, or a power outage.
This is a list of the overview information in this chapter.
What's New in Shutting Down and Booting a System?
This section describes new features that are related to shutting down and booting a system in the Solaris 9 release.
PXE Network Boot
You can boot the Solaris x86 Platform Edition directly from a network without the Solaris boot diskette on x86 based systems that support the Preboot Execution Environment (PXE) network booting protocol. The PXE network boot is available only for devices that implement the Intel Preboot Execution Environment specification.
You can enable the PXE network boot on the client system by using the BIOS setup program in the system BIOS, the network adapter BIOS, or both. On some systems, you must also adjust the boot device priority list so that a network boot is attempted before a boot from other devices. See the manufacturer's documentation for each setup program, or watch for setup program entry instructions during boot.
Some PXE-capable network adapters have a feature that enables a PXE boot if you type a particular keystroke in response to a brief boot-time prompt. This feature is ideal when you use PXE for an install boot on a system that normally boots from the disk drive because you do not have to modify the PXE settings. If your adapter does not have this feature, disable PXE in the BIOS setup when the system reboots after installation, and the system will boot from the disk drive.
Some early versions of PXE firmware cannot boot the Solaris system. If you have one of these older versions, your system can read the PXE network bootstrap program from a boot server, but the bootstrap will not transmit packets. If this problem occurs, upgrade the PXE firmware on the adapter. Obtain firmware upgrade information from the adapter manufacturer's web site. For more information, see elxl(7D) andiprb(7D).
For information on booting x86 based systems with or without the boot diskette, see x86: How to Boot a System From the Network.
Where to Find Shutting Down and Booting Tasks
Use these references to find step-by-step instructions for shutting down and booting a system.
Shut Down and Boot Task
For More Information
Shut down a SPARC based system or an x86 based system
Chapter 9, Shutting Down a System (Tasks)
Boot a SPARC based system
Chapter 10, SPARC: Booting a System (Tasks)
Boot an x86 based system
Chapter 11, x86: Booting a System (Tasks)
Manage a SPARC based system with the power management software
power.conf(4), pmconfig(1M)
Shutting Down and Booting Terminology
This section describes the terminology that is used in shutting down and booting a system.
Guidelines for Shutting Down a System
Keep the following in mind when you shut down a system:
Guidelines for Booting a System
Keep the following in mind when you boot a system:
Booting a System From the Network
You might need to boot a system from the network under the following situations:
In addition, there are two network configuration boot strategies available:
The default network boot strategy is set to RARP.
Use this table if you need information on booting a system over the network.
Network Boot Task
Boot a SPARC system or a SPARC diskless client
Boot an x86 system or an x86 diskless client
Boot a DHCP client during installation
Solaris 9 9/04 Installation Guide
Configure a DHCP client with DHCP Manager
System Administration Guide: IP Services
When to Shut Down a System
The following table provides a list of system administration tasks and the type of shut down that is needed to initiate the task.
Table 7–1 Shutting Down a System
Reason for System Shut Down
Appropriate Run Level
To turn off system power due to anticipated power outage
Run level 0, where it is safe to turn off power
To change kernel parameters in the /etc/system file
Run level 6 (reboot the system)
To perform file system maintenance, such as backing up or restoring system data
Run level S (single-user level)
To repair a system configuration file such as /etc/system
See When to Boot a System
N/A
To add or remove hardware from the system
Reconfiguration boot (also to turn off power when adding or removing hardware)
“Managing Devices (Tasks)” in System Administration Guide: Devices and File Systems
To repair an important system file which is causing system boot failure
N/A
To boot the kernel debugger (kadb) to track down a system problem
Run level 0, if possible
To recover from a hung system and you want to force a crash dump
N/A
For examples of shutting down a server or a standalone system, see Chapter 9, Shutting Down a System (Tasks).
The following table provides a list of system administration tasks and the corresponding boot type that is used to complete the task.
Table 7–2 Booting a System
Reason for System Reboot
Appropriate Boot Type
Information for SPARC Procedure
Information for x86 Procedure
Turn system power back on
Reboot the system to run level 3 (multiuser level with NFS resources shared)
SPARC: How to Boot a System to Run Level 3 (Multiuser Level)
x86: How to Boot a System to Run Level 3 (Multiuser Level)
To perform file system maintenance, such as performing a backup or restoring system data
Use Control-D from run level S to bring the system back to run level 3
SPARC: How to Boot a System to Run Level S (Single-User Level)
x86: How to Boot a System to Run Level S (Single-User Level)
Interactive boot
SPARC: How to Boot a System Interactively
x86: How to Boot a System Interactively
Reconfiguration boot (also to turn on system power after adding or removing hardware)
“Adding a System Disk or a Secondary Disk (Task Map)” in System Administration Guide: Devices and File Systems
Booting kabd
SPARC: How to Boot the System With the Kernel Debugger (kadb)
x86: How to Boot a System With the Kernel Debugger (kadb)
To repair an important system file that is causing system boot failure
Recovery boot
SPARC: How to Boot a System for Recovery Purposes
x86: How to Boot a System for Recovery Purposes
Recovery boot
See example on SPARC: How to Force a Crash Dump and Reboot the System
See example on x86: How to Force a Crash Dump and Reboot the System
For examples of booting a system, see Chapter 10, SPARC: Booting a System (Tasks) or Chapter 11, x86: Booting a System (Tasks).
