System Administration Guide: Basic Administration
SPARC: How to Stop the System for Recovery Purposes
  1. Type the stop key sequence for your system.
    The monitor displays the ok PROM prompt.
    ok
    The specific stop key sequence depends on your keyboard type. For example, you can press Stop-A or L1-A. On terminals, press the Break key.
  2. Synchronize the file systems.
    ok sync
  3. When you see the syncing file systems... message, press the stop key sequence for your system again.
  4. Type the appropriate boot command to start the boot process.
    For more information, see boot(1M).
  5. Verify that the system is booted to the specified run level.
    # who -r
     .       run-level 3  May  2 07:39     3      0  S
SPARC: Example—Stopping the System for Recovery Purposes
Press Stop-A
ok sync
Press Stop-A
ok boot
