System Administration Guide: Basic Administration
SPARC: How to Boot a System to Run Level S (Single-User Level)
Use this procedure to boot a system that is currently at run level 0 to run level S.
  1. Boot the system to run level S.
    ok boot -s
  2. Type the superuser password when the following message is displayed.
    INIT: SINGLE USER MODE
    Type Ctrl-d to proceed with normal startup,
    (or give root password for system maintenance):  xxx
  3. Verify that the system is at run level S.
    # who -r
    .       run-level S  Jun 10 15:27     3      0
  4. To bring the system up to multiuser state after you completed the system maintenance task, press Control-D.
SPARC: Example—Booting a System to Run Level S (Single-User Level)
The following example displays the messages from booting a system to run level S.
ok boot -s
Sun Microsystems Inc.   SunOS 5.9  Generic May 2002
Copyright 1983-2003 Sun Microsystems, Inc.  All rights reserved.
Use is subject to license terms.
configuring IPv4 interfaces: hme0.
Hostname: starbug
Type control-d to proceed with normal startup,
# who -r
   .       run-level S  Sep 19 08:49     S      0  ?
(Perform some maintenance task)
# Press Control-D
