System Administration Guide: Basic Administration
x86: Screens Displayed During the Device Identification Phase
Several screens are displayed as the Solaris Device Configuration Assistant attempts to identify devices on the system.
x86: Configuration Assistant Screen
This screen appears each time you boot the Solaris Device Configuration Assistant. The Solaris Device Configuration Assistant runs every time the system is booted, although the autoboot process bypasses the menus.
The Solaris(TM) (Intel Platform Edition) Device Configuration Assistant
scans to identify system hardware, lists identified devices, and can
boot the Solaris software from a specified device. This program must be
used to install the Solaris operating environment, add a driver,
or change the hardware on the system.
> To perform a full scan to identify all system hardware, choose Continue.
> To diagnose possible full scan failures, choose Specific Scan.
> To add new or updated device drivers, choose Add Driver.
About navigation...
    - The mouse cannot be used.
    - If the keyboard does not have function keys or they do not respond,
      press ESC. The legend at the bottom of the screen will change to
      show the ESC keys to use for navigation.
    - The F2 key performs the default action.
F2_Continue		F3_Specific Scan		F4_Add Driver		F6_Help
x86: Bus Enumeration Screen
The Bus Enumeration screen appears briefly while the Solaris Device Configuration Assistant gathers hardware configuration data for devices that can be detected automatically.
Bus Enumeration
Determining bus types and gathering hardware configuration data ...
Please wait ...
x86: Scanning Devices Screen
The Scanning Devices screen appears while the Solaris Device Configuration Assistant manually scans for devices that can only be detected with special drivers.
Scanning Devices
The system is being scanned to identify system hardware.
If the scanning stalls, press the system's reset button. When the
system reboots, choose Specific Scan or Help.
Scanning: Floppy disk controller
0	 		 20       40        60	       80       100
Please wait ...
x86: Identified Devices Screen
The Identified Devices screen displays which devices have been identified on the system. From here, you can continue to the Boot Solaris menu or perform optional device tasks, such as setting a keyboard configuration, viewing and editing devices, setting up a serial console, and saving and deleting configurations.
Identified Devices
The following devices have been identified on this system. To identify
devices not on this list or to modify device characteristics, such as
keyboard configuration, choose Device Tasks. Platform types may be
included in this list.
ISA: Floppy disk controller
	ISA: Motherboard
	ISA: PnP bios: 16550-compatible serial controller
	ISA: PnP bios: Mouse controller
	ISA: PnP bios: Parallel port
	ISA: System keyboard (US-English)
	PCI: Bus Mastering IDE controller
	PCI: Universal Serial Bus
	PCI: VGA compatible display adapter
F2_Continue   F3_Back   F4_Device Tasks   F6_Help
