System Administration Guide: Basic Administration
Using the Solaris Management Tools in a Name Service Environment (Task Map)
By default, the Solaris management tools are set up to operate in a local environment. For example, the Mounts and Shares tool enables you to mount and share directories on specific systems, but not in a NIS or NIS+ environment. However, you can manage information with the Users and Computers and Networks tools in a name service environment.
To work with a console tool in a name service environment, you need to create a name service toolbox, and then add the tool to that toolbox.
Task
Description
For Instructions
1. Verify prerequisites
Verify you have completed the prerequisites before attempting to use the console in a name service environment.
Prerequisites for Using the Solaris Management Console in a Name Service Environment
2. Create a toolbox for the name service
Use the New Toolbox wizard to create a toolbox for your name service tools.
How to Create a Toolbox for a Specific Environment
3. Add a tool to the name service toolbox
Add the Users tool, or any other name service tool, to your name service toolbox.
How to Add a Tool to a Toolbox
4. Select the toolbox just created
Select the toolbox you just created to manage name service information.
How to Start the Solaris Management Console in a Name Service Environment
RBAC Security Files
The RBAC security files that work with the Solaris Management Console are created when you upgrade to or install the Solaris 9 release. If you do not install the Solaris Management Console packages, the RBAC security files are installed without the necessary data for using RBAC. For information on the Solaris Management Console packages, see Troubleshooting the Solaris Management Console.
The RBAC security files in the Solaris 9 release are included in your name service so that you can use the Solaris Management Console tools in a name service environment.
The security files on a local server are populated into a name service environment as part of a standard upgrade by the ypmake, nispopulate, or equivalent LDAP commands. The following name services are supported:
Note –
The projects database is not supported in the NIS+ environment.
The RBAC security files are created when you upgrade to or install the Solaris 9 release.
This table briefly describes the pre-defined security files that are installed on a Solaris 9 system.
Table 2–3 RBAC Security Files
Local File Name
Table or Map Name
Description
/etc/user_attr
user_attr
Associates users and roles with authorizations and rights profiles.
/etc/security/auth_attr
auth_attr
Defines authorizations and their attributes and identifies associated help files.
/etc/security/prof_attr
prof_attr
Defines rights profiles, lists the rights profiles assigned authorizations and identifies associated help files.
/etc/security/exec_attr
exec_attr
Defines the privileged operations assigned to a rights profile.
For unusual upgrade cases, you might have to use the smattrpop command to populate RBAC security files in the following instances:
For more information, see “Role-Based Access Control (Overview)” in System Administration Guide: Security Services.
The following table identifies what you need to do before you can use the Solaris Management Console in a name service environment.
Prerequisite
For More Information
Install the Solaris 9 release.
Solaris 9 9/04 Installation Guide
Set up your name service environment.
System Administration Guide: Naming and Directory Services (DNS, NIS, and LDAP)
Select your management scope.
Management Scope
Make sure your/etc/nsswitch.conf file is configured so that you can access your name service data.
The /etc/nsswitch.conf File
Management Scope
The Solaris Management Console uses the term management scope to refer to the name service environment that you want to use with the selected management tool. The management scope choices for the Users and Computers and Networks tools are LDAP, NIS, NIS+, or files.
The management scope that you select during a console session should correspond to the primary name service identified in the /etc/nsswitch.conf file.
The /etc/nsswitch.conf file on each system specifies the policy for name service lookups (where data is read from) on that system.
Note –
You must make sure that the name service accessed from the console, which you specify through the console Toolbox Editor, appears in the search path of the /etc/nsswitch.conf file. If the specified name service does not appear there, the tools might behave in unexpected ways, resulting in errors or warnings.
When using the Solaris managements tools in a name service environment, you might impact many users with a single operation. For example, if you delete a user in the NIS name service, that user is deleted on all systems that are using NIS.
If different systems in your network have different /etc/nsswitch.conf configurations, unexpected results might occur. So, all systems to be managed with the Solaris management tools should have a consistent name service configuration.
Applications for administering the Solaris operating system are called tools, and those tools are stored in collections referred to as toolboxes. A toolbox can be located on a local server, where the console is located, or on a remote machine.
Use the Toolbox Editor to add a new toolbox, to add tools to an existing toolbox, or to change the scope of a toolbox. For example, to change the domain from local files to a name service.
Note –
You can start the Toolbox Editor as a normal user. However, if you plan to make changes and save them to the default console toolbox, /var/sadm/smc/toolboxes, you must start the Toolbox Editor as root.
  1. Start the Toolbox Editor.
    # /usr/sadm/bin/smc edit &
  2. Select Open from the Toolbox menu.
  3. Select the This Computer icon in the Toolboxes: window.
  4. Click Open.
    The This Computer toolbox opens in the window.
  5. Select the This Computer icon again in the Navigation pane.
  6. Select Add Folder from the Action menu.
  7. Use the Folder wizard to add a new toolbox for your name service environment.
    1. Name and Description – Provide a name in the Full Name window. Click Next.
      For example, “NIS tools” for the NIS environment.
    2. Provide a description in the Description window. Click Next.
      For example, “tools for NIS environment.”
    3. Icons – Use the default value for the Icons. Click Next.
    4. Management Scope – Select Override.
    5. Select your name service under the Management Scope pull-down menu.
    6. Add the name service master name in the Server: field, if necessary.
    7. Add the domain managed by the server in the Domain: field.
    8. Click Finish.
      The new toolbox appears in the left Navigation pane.
  8. Select the new toolbox icon.
  9. Select Save As from the Toolbox menu.
  10. Enter the toolbox path name in the Local Toolbox Filename: dialog box. Use the .tbx suffix.
    /var/sadm/smc/toolboxes/this_computer/toolbox-name.tbx
  11. Click Save.
    The new toolbox appears in the Navigation pane in the console window.
Where to Go From Here
After you have created a name service toolbox, you can put a name service tool into it. For more information, see How to Add a Tool to a Toolbox.
In addition to the default tools that ship with the console, additional tools that can be launched from the console are being developed. As these tools become available, you can add one or more tools to an existing toolbox.
You can also create a new toolbox, for either local management or network management, and then add tools to the new toolbox.
  1. Become superuser or assume an equivalent role.
  2. Start the Toolbox Editor, if necessary.
  3. Select the toolbox.
    If you want to work in a name service, select the toolbox you just created in the Toolbox Editor.
    For more information, see How to Create a Toolbox for a Specific Environment.
  4. Select Add Tool from the Action menu.
  5. Use the Add Tool wizard to add the new tool.
    1. Server Selection – Add the name service master in the Server: window. Click Next.
    2. Tools Selection – Select the tool you want to add from the Tools: window. Click Next.
      If this tool box is a name service toolbox, choose a tool you want to work in a name service environment. For example, the Users Tools.
    3. Name and Description – Accept the default values. Click Next.
    4. Icons – Accept the default values, unless you have created custom icons. Click Next.
    5. Management Scope – Accept the default value “Inherit from Parent.” Click Next.
    6. Tool Loading – Accept the default “Load tool when selected.” Click Finish.
  6. Select Save from the Toolbox menu to save the updated toolbox.
    The Local Toolbox window is displayed.
After you have created a name service toolbox and have added tools to it, you can start the Solaris Management Console and open that toolbox to manage a name service environment.
  1. Verify that the following prerequisites are met.
    1. Be sure the system you are logged into is configured to work in a name service environment.
    2. Verify that the /etc/nsswitch.conf file is configured to match your name service environment.
  2. Start the Solaris Management Console.
    For more information, see How to Start the Console as Superuser or as a Role.
  3. Select the toolbox you created for the name service, which appears in the Navigation pane.
    For information on creating a toolbox for a name service, see How to Create a Toolbox for a Specific Environment.
