System Administration Guide: Basic Administration
Selecting the Best Method for Adding Signed Patches
After you have installed a patch management tool, you can use several different methods of downloading or adding a signed patch or patches to your system. Use the following table to determine which method is best for your needs.
Command or Tool
Description
For More Information
patchadd
Starting in the Solaris 9 12/03 release – Use this command to add signed patches to your system after your have set up your package keystore.
patchadd(1M)
smpatch update
Solaris 2.6, Solaris 7, Solaris 8, and at least Solaris 9 4/03 – Use this command to identify the recommended patches and automatically download and apply the patches to your system. Notice that this command will not apply a patch that has the interactive property set.
smpatch(1M)
smpatch analyze
Use this command to identify required patches and display a list of required patch IDs for your system. Then, you could use the smpatch download and smpatch add commands to download and add the patches to your system.
smpatch(1M)
Use these commands to download and apply one or more patches to your system. These commands also download and apply any prerequisite patches.
“Downloading and Applying Signed Patches to a Solaris System (Task Map)” in Signed Patches Administration Guide for PatchPro 2.2
ftp and smpatch add
Use the ftp command to transfer a patch or patches to your system. Then, use the smpatch add command to add the patch or patches to your system.
Solaris Management Console Patches Tool
For Solaris 9 systems only – Use this tool when you want the convenience of a GUI tool to manage signed patches.
Solaris Management Console online help
