Use this map to identify all the tasks for managing patches in the Solaris environment. Each task points to a series of additional tasks such as managing signed or unsigned patches.
Task |
Description |
For Instructions |
Determine if adding signed or unsigned patches |
Determine whether adding signed or unsigned patches is best for your environment. | |
Add a signed or unsigned patch to your system |
You can add signed patches with either of the following commands: |
Use the patchadd command starting in the Solaris 9 12/03 release. | |
Use the smpatch command in the Solaris 2.6, 7, 8, or 9 releases. | |
Add an unsigned patch to your system. |
The key factor in determining when to add signed or unsigned patches is whether or not the secure download of patches is important in your environment. If the secure download of patches is important in your environment, then add signed patches to your system.
