System Administration Guide: Basic Administration
Managing Software With the Solaris Product Registry GUI (Task Map)
The following task map describes the software management tasks that you can do with the Solaris Product Registry.
Task
Description
For Instructions
View installed or uninstalled software with the Product Registry
You can view installed or uninstalled software with the Product Registry.
How to View Installed or Uninstalled Software Information With the Product Registry GUI
Install software with the Product Registry
You can use Product Registry to find software and launch the Solaris Web Start program, which leads you through the installation of that software.
How to Install Software With the Product Registry GUI
Uninstall software with the Product Registry
You can uninstall software with the Product Registry.
How to Uninstall Software With the Product Registry GUI
The Solaris Product Registry is a tool to help you manage installed software. After you have installed the software, Product Registry provides a list of all the installed software by using the Solaris Web Start program 3.0 or the Solaris pkgadd command.
You can use the Solaris Product Registry in a GUI or with a command-line interface (CLI). For more information on how to use the Solaris Product Registry CLI, see Managing Software With the Solaris Product Registry Command-Line Interface (Task Map).
The Solaris Product Registry GUI interface enables you to do the following:
The Solaris Product Registry GUI main window consists of three areas of information:
Figure 14–1 Solaris Product Registry Window
Simple screen capture titled Solaris Product Registry. Shows the Registered Software, Summary, and More Information panes.
  1. Become superuser or assume an equivalent role.
  2. Start the Product Registry tool.
    # prodreg &
    The Solaris Product Registry main window is displayed.
  3. Click the turner control to the left of the System registry directory in the Registered Software box.
    Notice that the turner control changes from pointing to the right to pointing down. You can expand or collapse any item in the Registry, except an item that has a text file icon to its left.
    The Software Installed in Registered Software box always contains the following:
    • The configuration software group that you chose when installing the Solaris release. Software groups that can be displayed include Core, End User System Support, Developer System Support, Entire Distribution, or Entire Distribution Plus OEM Support.
    • Additional system software, which is Solaris products that are not part of the software group you chose.
    • Unclassified software, which is any package that you installed by using the pkgadd command that is not a Solaris product or part of the software group.
  4. Select directories until you find a software application to view.
    The list expands as you open directories.
  5. To view the attributes, select a directory or file.
    The Product Registry displays attribute information in the System Registry box.
    • For software products that were installed with the Solaris Web Start program, the Product Registry contains values for at least the following: Title, Version, Location, and Installed on. Items in an expanded list under a product or software group inherit the version information of the product.
    • If all or part of the product was removed with the pkgrm command, a cautionary icon appears next to the software product's name.
    # prodreg
    The Solaris Product Registry window is displayed.
  3. Decide if you are installing from a CD, a DVD, or from the network. Select one of the following:
    • If you are installing from a CD, insert the CD into the CD-ROM drive.
    • If you are installing from a DVD, insert the DVD into the DVD-ROM drive.
    • If you are installing from the network, locate the net image of the software that you want to install.
  4. To view the list of installed and registered software, click the turner control.
  5. Click the New Install button at the bottom of the Solaris Product Registry window.
    The Product Registry displays the Select Installer dialog box, which initially points to the /cdrom directory or the directory you are in.
  6. Select directories to find the Solaris Web Start program installer.
    Solaris Web Start installers are located in various directories on the CDs and on the DVD. For specific information about CD and DVD structures, see “Organization of Solaris 9 Media (Reference)” in Solaris 9 9/04 Installation Guide.
    • Solaris 9 Software 1 of 2 and 2 of 2 CD.
    • Solaris 9 Software 2 of 2 CD.
    • Solaris 9 Documentation CD.
    • Solaris 9 Languages CD. The Solaris Web Start program automatically starts when the CD is inserted.
  7. When you find the installer you want, select its name in the Files box.
  8. Click OK.
    The installer you selected is launched.
  9. Follow the directions that are displayed by the installer to install the software.
    # prodreg
  3. To view the list of installed and registered software, click the turner control.
  4. Select directories until you find the name of the software that you want to uninstall.
  5. Read the software attributes to make sure that this software is the software that you want to uninstall.
  6. Click the Uninstall software-product-name button at the bottom of the Solaris Product Registry window.
    The software product you selected is uninstalled.
