System Administration Guide: Basic Administration
How to Remove Software Packages (pkgrm)
  1. Become superuser or assume an equivalent role.
  2. Remove an installed package.
    # pkgrm pkgid ...
    pkgid identifies the name of one or more packages, separated by spaces, to be removed. If omitted, pkgrm removes all available packages.
Example—Removing Software Packages
This example shows how to remove a package.
# pkgrm SUNWctu
The following package is currently installed:
   SUNWctu         Netra ct usr/platform links (64-bit)
                   (sparc.sun4u) 11.9.0,REV=2001.07.24.15.53
Do you want to remove this package? y
## Removing installed package instance <SUNWctu>
## Verifying package dependencies.
## Processing package information.
## Removing pathnames in class <none>
Example—Removing a Spooled Software Package
This example shows how to remove a spooled package.
# pkgrm -s /export/pkg SUNWaudh
The following package is currently spooled:
   SUNWaudh        Audio Header Files
                   (sparc) 11.10.0,REV=2003.08.08.00.03
Removing spooled package instance <SUNWaudh>
