This chapter describes how to set up and maintain user accounts and groups by using the Solaris Management Console.
For information on the procedures associated with setting up and maintaining user accounts and groups with the Solaris Management Console, see Setting Up User Accounts (Task Map) and Maintaining User Accounts (Task Map).
For background information about managing user accounts and groups, see Chapter 3, Managing User Accounts and Groups (Overview).
Task |
Description |
For Instructions |
(Optional) Gather user information |
Use a standard form to gather user information to help you keep user information organized. | |
(Optional) Customize user initialization files |
You can set up user initialization files (.cshrc, .profile, .login), so you can provide new users with consistent environments. | |
(Optional) Add a group |
You can add a group with the following tools: |
Solaris Management Console's Groups tool |
How to Add a Group with the Solaris Management Console's Groups Tool |
Solaris command line interface tools | |
Add a user |
You can add a user with the following tools: |
Solaris Management Console's Users Tool |
How to Add a User With the Solaris Management Console's Users Tool |
(Optional) Set up a user template |
You can create a user template so you don't have to manually add all similar user properties. |
See Solaris Management Console online help |
(Optional) Add rights or a role to a user |
You can add rights or a role to a user so the user can perform a specific command or task. |
Share the user's home directory |
You must share the user's home directory so the directory can be remotely mounted from the user's system. | |
Mount the user's home directory |
You must mount the user's home directory on the user's system. |
You can create a form like the one that follows to gather information about users before adding their accounts.
Item |
Description |
User Name: |
Role Name: |
Profiles or Authorizations: |
User Name: |
UID: |
Primary Group: |
Secondary Groups: |
Comment: |
Default Shell: |
Password Status and Aging: |
Home Directory Server Name: |
Home Directory Path Name: |
Mounting Method: |
Permissions on Home Directory: |
Mail Server: |
Department Name: |
Department Administrator: |
Manager: |
Employee Name: |
Employee Title: |
Employee Status: |
Employee Number: |
Start Date: |
Add to These Mail Aliases: |
Desktop System Name: |
Become superuser or assume an equivalent role on the system where the users' home directories are created and shared.
Create a skeleton directory for each type of user.
# mkdir /shared-dir/skel/user-type |
shared-dir |
The name of a directory that is available to other systems on the network. |
user-type |
The name of a directory to store initialization files for a type of user. |
Copy the default user initialization files into the directories you created for different types of users.
# cp /etc/skel/local.cshrc /shared-dir/skel/user-type/.cshrc # cp /etc/skel/local.login /shared-dir/skel/user-type/.login # cp /etc/skel/local.profile /shared-dir/skel/user-type/.profile |
If the account has profiles assigned to it, then the user has to launch a special version of the shell called a profile shell to use commands (with any security attributes) that are assigned to the profile. There are three profile shells corresponding to the types of shells: pfsh (Bourne shell), pfcsh (C shell), and pfksh (Korn shell).
Edit the user initialization files for each user type and customize them based on your site's needs.
For a detailed description on the ways to customize the user initialization files, see Customizing a User's Work Environment.
Set the permissions for the user initialization files.
# chmod 744 /shared-dir/skel/user-type/.* |
Verify that the permissions for the user initialization files are correct.
# ls -la /shared-dir/skel/* |
The following example shows how to customize the C-shell user initialization file in the /export/skel/enduser directory designated for a particular type of user. For an example of a .cshrc file, see Example—.cshrc File.
# mkdir /export/skel/enduser # cp /etc/skel/local.cshrc /export/skel/enduser/.cshrc (Edit .cshrc file ) # chmod 744 /export/skel/enduser/.* |
Use this procedure to add a group to the system.
Become superuser or assume an equivalent role.
Start the Solaris Management Console.
# /usr/sadm/bin/smc & |
For more information on starting the Solaris Management Console, see How to Start the Console as Superuser or as a Role or How to Start the Solaris Management Console in a Name Service Environment.
Double-click the This Computer icon under the Management Tools icon in the Navigation pane.
A list of categories is displayed.
(Optional) Select the appropriate toolbox for your name service environment.
Double-click the System Configuration icon.
Double-click the User Accounts icon.
Provide the superuser password or the role password.
Double-click the Groups icon.
Use the Context help to add a group to the system.
The following example identifies the steps to add the group mechanoids (group ID 101) to the system starbug. This example assumes that the launcher has been started and Users tool is open.
You can add existing users to the group when you add the group. Or, you can just add the group and then add the user to the group when you add the user.
Select Add Group from the Action menu.
Identify the group name, mechanoids, at the Group Name prompt under Group Identification.
Identify the group number, 101, at the Group ID number prompt.
Click on OK.
Use the following procedure to add a user to the system.
Double-click the Users icon.
Use the Context help to add a user to the system.
The following example identifies the steps to add the user kryten (user ID 1001) to the system starbug. This example assumes that the launcher has been started and Users Tool is open.
Click Next between the steps below.
Select Add User—>With Wizard from the Action menu.
Step 1 – Identify the user's name or login name, kryten, at the User Name prompt under Group Identification.
(Optional) Identify the user's full name, kryten series 3000, at the Full Name prompt.
(Optional) Provide a further description of this user at the Description prompt.
Step 2 – Provide the user ID, 1001, at the User ID Number prompt.
Step 3 – Select the User Must Use This Password At First Login option.
Provide a password for the user at the Password prompt and then confirm the password at the Confirm Password prompt.
Step 4 – Select the user's primary group, mechanoids.
Step 5 – Create the user's home directory by accepting the defaults at the Server and Path prompts.
Step 6 – Specify the mail server.
Step 7 – Review the information you provided and go back to correct the information, if necessary. Otherwise, click on Finish.
This section provides examples of adding users and groups with CLI tools.
The following example shows how to use the groupadd and useradd commands to add the group scutters and user scutter1 to files on the local system. These commands cannot be used to manage users in a name service environment.
# groupadd -g 102 scutters # useradd -u 1003 -g 102 -d /export/home/scutter1 -s /bin/csh -c "Scutter 1" -m -k /etc/skel scutter1 64 blocks |
For more information, see groupadd(1M) and useradd(1M).
The following example shows how to use the smgroup and smuser commands to add the group gelfs and the user camille to the NIS domain solar.com on the host starbug.
# /usr/sadm/bin/smgroup add -D nis:/starbug/solar.com -- -g 103 -n gelfs # /usr/sadm/bin/smuser add -D nis:/starbug/solar.com -- -u 1004 -n camille -c "Camille G." -d /export/home/camille -s /bin/csh -g gelfs |
For more information, see smgroup(1M) and smuser(1M).
Become superuser or assume an equivalent role on the system that contains the home directory.
Verify that the mountd daemon is running.
# ps -ef | grep mountd root 176 1 0 May 02 ? 0:19 /usr/lib/nfs/mountd |
The /usr/lib/nfs/mountd line shows whether the mountd daemon is running.
If the mountd daemon is not running, start it.
# /etc/init.d/nfs.server start |
List the file systems that are shared on the system.
# share |
Select one of the following based on whether the file system containing the user's home directory is already shared.
If the user's home directory is already shared, go to the verification step below.
If the user's home directory is not shared, go to Step 6.
Edit the /etc/dfs/dfstab file and add the following line.
share -F nfs /file-system |
file-system is the file system containing the user's home directory that you need to share. By convention, the file system is /export/home.
Share the file systems listed in the /etc/dfs/dfstab file.
# shareall -F nfs |
This command executes all the share commands in the /etc/dfs/dfstab file, so you do not have to wait to reboot the system.
Verify that a user's home directory is shared, as follows:
# share |
If the user's home directory is not located on the user's system, you have to mount the user's home directory from the system where it is located. For detailed instructions, see How to Mount a User's Home Directory.
# ps -ef | grep mountd # /etc/init.d/nfs.server start # share # vi /etc/dfs/dfstab (The line share -F nfs /export/home is added.) # shareall -F nfs # share - /usr/dist ro "" - /export/home/user-name rw "" |
For information on automounting a home directory, see “Task Overview for Autofs Administration” in System Administration Guide: Resource Management and Network Services.
Make sure that the user's home directory is shared.
For more information, see How to Share a User's Home Directory.
Log in as superuser on the user's system.
Edit the /etc/vfstab file and create an entry for the user's home directory.
system-name:/export/home/user-name - /export/home/user-name nfs - yes rw |
system-name |
The name of the system where the home directory is located. |
/export/home/user-name |
The name of the user's home directory that will be shared. By convention, /export/homeuser-name contains user's home directories. However, this could be a different file system. |
Required placeholders in the entry. |
The name of the directory where the user's home directory will be mounted. |
For more information about adding an entry to the /etc/vfstab file, see “Mounting and Unmounting File Systems (Tasks)” in System Administration Guide: Devices and File Systems.
Create the mount point for the user's home directory.
# mkdir -p /export/home/user-name |
Mount the user's home directory.
# mountall |
All entries in the current vfstab file (whose mount at boot fields are set to yes) are mounted.
Verify that the home directory is mounted.
# mount | grep user-name |
# vi /etc/vfstab (The line venus:/export/home/ripley - /export/home/ripley nfs - yes rw is added.) # mkdir -p /export/home/ripley # mountall # mount / on /dev/dsk/c0t0d0s0 read/write/setuid/intr/largefiles/xattr/onerror= ... /usr on /dev/dsk/c0t0d0s6 read/write/setuid/intr/largefiles/xattr/onerror= ... /proc on /proc read/write/setuid/dev=3dc0000 on Fri Apr 2 13:26:30 2004 /etc/mnttab on mnttab read/write/setuid/dev=3e80000 on Fri Apr 2 13:26:30 2004 /dev/fd on fd read/write/setuid/dev=3ec0000 on Fri Apr 2 13:26:33 2004 /var/run on swap read/write/setuid/xattr/dev=1 on Fri Apr 2 13:26:34 2004 /tmp on swap read/write/setuid/xattr/dev=2 on Fri Apr 2 13:26:38 2004 /export/home on /dev/dsk/c0t0d0s7 read/write/setuid/intr/largefiles/xattr... /export/home/ripley on venus:/export/home/ripley remote/read/write/setuid/xattr/dev=... |
Task |
Description |
Instructions |
Modify a Group |
You can modify a group's name or the users in a group by using the Groups Tool. |
Delete a Group |
You can delete a group if its no longer needed. |
Modify a User Account |
Disable a User Account You can temporarily disable a user account if it will be needed in the future. |
Change a User's Password You might need to change a user's password if the user forgets it. |
Change Password Aging You can force users to change their passwords periodically with User Account tool's Password Options menu. |
Delete a User Account |
You can delete a user account if it is no longer needed. |
Solaris User Registration is a tool for getting information about new Solaris releases, upgrade offers, and promotions. This graphical user interface (GUI) automatically starts when you first log into your desktop. The GUI lets you register now, later, or never. The registration process also provides Sun with the user's Solaris version, survey type, platform, hardware, and locale.
Completing the Solaris User Registration process provides access to Solaris SolveSM, an exclusive web site that offers valuable Solaris product information and solutions—all in one convenient location. It provides a quick and easy method for getting the most recent information on what's happening around the latest Solaris release. Solaris Solve also provides a preview to additional Sun contract and service opportunities.
Basically, the steps for completing Solaris User Registration and accessing Solaris Solve are:
Fill in the electronic Solaris User Registration profile.
Submit the profile by email or print the profile to fax or mail.
Create your login ID and password to access the Solaris Solve site.
Even if you do not access the Solaris Solve site immediately, we recommend that you create your Solaris Solve login ID and password during the Solaris User Registration process. A Solaris Solve login ID and password should contain 6 to 8 alphanumeric characters without spaces and colons.
Access the Solaris Solve site.
Solaris User Registration is not invoked if the system administrator or user is logged in as superuser.
If you choose to register, a copy of the completed form is stored in $HOME/.solregis/uprops. If you choose to never register and change your mind later, you can start User Registration by:
Typing /usr/dt/bin/solregis at any command line prompt, or
Clicking the Registration icon in the Application Manager's desktop tools folder (Common Desktop Environment desktop only)
For more information, see solregis(1).
This section provides troubleshooting tips for solving Solaris User Registration problems.
The following table describes problems that may occur when you try to register, and actions required to resolve these conflicts.
Table 4–1 Registration Problem Descriptions and Suggested Resolutions
Problem Description |
How to Resolve the Problem |
The registration form failed to initialize: Web page window displays and requests user see system administrator to resolve problem that prevents registration setup. |
Check for missing registration files. |
The form could not be emailed: Dialog box displays and requests user see system administrator to resolve problem. |
Check to see if email is configured correctly. Also check if CDE is on user's system since it must be present to email completed registration form. Alternatively, users can print the form and fax or mail it. |
The form could not be printed: Dialog box displays and requests user to see system administrator to resolve problem. |
Check to see if the printer is configured correctly. Alternatively, the user can email form. |
The form could not be saved: Dialog box displays and verifies that registration succeeded; however, the registration information cannot be recalled when updating registration in the future. |
Check the user's home directory. Required action depends on the system's configuration. |
You forgot your Solaris Solve login ID and password. |
Send a mail message describing the problem to SolarisSolve@sun.com or see How to Restart Solaris User Registration. |
You want to restart the registration process. |
Use the following procedure to restart the Solaris User Registration process.
Change to the $HOME/.solregis directory.
% cd $HOME/.solregis |
Remove the uprops file.
% rm uprops |
Restart the registration process.
% /usr/dt/bin/solregis & |
You can disable User Registration before or after installing Solaris software. Before disabling Solaris User Registration, Sun recommends that system administrators register for their organization.
To disable user registration before installing the Solaris release, select one of the following:
Deselect the SUNWsregu package (interactive installation).
Modify a custom JumpStart profile to not install the SUNWsregu package.
Create and run a finish script that creates a file named solregis in the /etc/default directory on one or more systems with the following line in the script:
DISABLE=1 |
For more information see Solaris 9 9/04 Installation Guide or solregis(1).
To disable user registration after installing the Solaris release, select one of the following:
Remove the SUNWsregu package
Add the solregis file to the /etc/default directory.
