Full
Copies a complete file system or directory
All data is in one place
Requires large numbers of backup tapes that take a long time to write.
Takes longer to retrieve individual files because the drive has to move sequentially
to the point on the tape where the file is located. You might have to search
multiple tapes.
Snapshot
Creates a temporary image of a file system
System can be in multiuser mode
System performance might degrade while the snapshot is created.
Incremental
Copies only those files in the specified file system that have
changed since a previous backup
Easier to retrieve small changes in file systems
Finding which incremental tape contains a file can take time. You might
have to go back to the last full backup.
