System Administration Guide: Devices and File Systems
Default ufsdump Options
If you run the ufsdump command without any options, use this syntax:
# ufsdump filenames
The ufsdump command uses these options and arguments, by default:
ufsdump 9uf /dev/rmt/0 filenames
These options do a level 9 incremental backup to the default tape drive at its preferred density.
