System Administration Guide: Devices and File Systems
ProcedureHow to Retrieve Specific Files From a Tape (cpio)
Steps
  1. Change to the directory where you want to put the files.
  2. Insert the tape into the tape drive.
  3. Retrieve a subset of files from the tape.
    $ cpio -icv "*file" < /dev/rmt/n
    -i
    Extracts files from standard input.
    -c
    Specifies that the cpio command should read headers in ASCII character format.
    -v
    Displays the files as they are retrieved in a format that is similar to the output from the ls command.
    "*file"
    Specifies that all files that match the pattern are copied to the current directory. You can specify multiple patterns, but each pattern must be enclosed in double quotation marks.
    < /dev/rmt/n
    Specifies the input file.
    For more information, see the cpio(1) man page.
  4. Verify that the files were copied.
    $ ls -l
Example 27–10 Retrieving Specific Files From a Tape (cpio)
The following example shows how to retrieve all files with the chapter suffix from the tape in drive 0.
$ cd /home/smith/Book
$ cpio -icv "*chapter" < /dev/rmt/0
Boot.chapter
Directory.chapter
Install.chapter
Intro.chapter
31 blocks
$ ls -l
