The Solaris release includes the fssnap command for backing up file systems while the file system is mounted. You can use the fssnap command to create a read-only snapshot of a file system. A snapshot is a file system's temporary image that is intended for backup operations.
When the fssnap command is run, it creates a virtual device and a backing-store file. You can back up the virtual device, which looks and acts like a real device, with any of the existing Solaris backup commands. The backing-store file is a bitmap file that contains copies of presnapshot data that has been modified since the snapshot was taken.
The UFS snapshots feature enables you to keep the file system mounted and the system in multiuser mode during backups. Previously, you were advised to bring the system to single-user mode to keep the file system inactive when you used the ufsdump command to perform backups. You can also use additional Solaris backup commands, such as tar and cpio, to back up a UFS snapshot for more reliable backups.
The fssnap command gives administrators of nonenterprise-level systems the power of enterprise-level tools, such as Sun StorEdgeTM Instant Image, without the large storage demands.
The UFS snapshots feature is similar to the Instant Image product. Although UFS snapshots can make copies of large file systems, Instant Image is better suited for enterprise-level systems. UFS snapshots is better suited for smaller systems. Instant Image allocates space equal to the size of the entire file system that is being captured. However, the backing-store file that is created by UFS snapshots occupies only as much disk space as needed.
This table describes specific differences between UFS snapshots and Instant Image.
UFS Snapshots |
Sun StorEdge Instant Image |
Size of the backing-store file depends on how much data has changed since the snapshot was taken |
Size of the backing-store file equivalent equals the size of the entire file system being copied |
Does not persist across system reboots |
Persists across system reboots |
Works on UFS file systems |
Cannot be used with root (/) or /usr file systems |
Available starting with the Solaris 8 1/01 release |
Part of Sun StorEdge products |
When the UFS snapshot is first created, users of the file system might notice a slight pause. The length of the pause increases with the size of the file system to be captured. While the snapshot is active, users of the file system might notice a slight performance impact when the file system is written to, but they see no impact when the file system is read.
