System Administration Guide: Devices and File Systems
Chapter 24 Using UFS Snapshots (Tasks)
This chapter describes how to create and back up UFS snapshots.
For information on the procedures associated with creating UFS snapshots, see Using UFS Snapshots (Task Map).
For overview information about performing backups, see Chapter 22, Backing Up and Restoring File Systems (Overview).
Task
Description
For Instructions
1. Create a UFS snapshot
Create a read-only copy of a file system by using the fssnap command.
How to Create a UFS Snapshot
2. Display UFS snapshot information
Identify UFS snapshot information such as the raw snapshot device.
How to Display UFS Snapshot Information
3. (Optional) Delete a UFS snapshot
Delete a snapshot that is already backed up or no longer needed.
How to Delete a UFS Snapshot
4. Back up a UFS snapshot
Choose one of the following backup methods:
Create a full backup of a UFS snapshot by using the ufsdump command.
How to Create a Full Backup of a UFS Snapshot (ufsdump)
Create an incremental backup of a UFS snapshot by using the ufsdump command.
How to Create an Incremental Backup of a UFS Snapshot (ufsdump)
Back up a UFS snapshot by using the tar command.
How to Back Up a UFS Snapshot (tar)
5. (Optional) Restore data from a UFS snapshot
Restore the UFS snapshot the same way as you would restore data by using the ufsrestore command.
How to Restore a Complete File System
UFS Snapshots Overview
The Solaris release includes the fssnap command for backing up file systems while the file system is mounted. You can use the fssnap command to create a read-only snapshot of a file system. A snapshot is a file system's temporary image that is intended for backup operations.
When the fssnap command is run, it creates a virtual device and a backing-store file. You can back up the virtual device, which looks and acts like a real device, with any of the existing Solaris backup commands. The backing-store file is a bitmap file that contains copies of presnapshot data that has been modified since the snapshot was taken.
Why Use UFS Snapshots?
The UFS snapshots feature enables you to keep the file system mounted and the system in multiuser mode during backups. Previously, you were advised to bring the system to single-user mode to keep the file system inactive when you used the ufsdump command to perform backups. You can also use additional Solaris backup commands, such as tar and cpio, to back up a UFS snapshot for more reliable backups.
The fssnap command gives administrators of nonenterprise-level systems the power of enterprise-level tools, such as Sun StorEdgeTM Instant Image, without the large storage demands.
The UFS snapshots feature is similar to the Instant Image product. Although UFS snapshots can make copies of large file systems, Instant Image is better suited for enterprise-level systems. UFS snapshots is better suited for smaller systems. Instant Image allocates space equal to the size of the entire file system that is being captured. However, the backing-store file that is created by UFS snapshots occupies only as much disk space as needed.
This table describes specific differences between UFS snapshots and Instant Image.
UFS Snapshots
Sun StorEdge Instant Image
Size of the backing-store file depends on how much data has changed since the snapshot was taken
Size of the backing-store file equivalent equals the size of the entire file system being copied
Does not persist across system reboots
Persists across system reboots
Works on UFS file systems
Cannot be used with root (/) or /usr file systems
Available starting with the Solaris 8 1/01 release
Part of Sun StorEdge products
UFS Snapshots Performance Issues
When the UFS snapshot is first created, users of the file system might notice a slight pause. The length of the pause increases with the size of the file system to be captured. While the snapshot is active, users of the file system might notice a slight performance impact when the file system is written to, but they see no impact when the file system is read.
Creating and Deleting UFS Snapshots
When you use the fssnap command to create a UFS snapshot, observe how much disk space the backing-store file consumes. The backing-store file uses no space, and then it grows quickly, especially on heavily used systems. Make sure that the backing-store file has enough space to expand. Or, limit its size with the -o maxsize=n [k,m,g] option, where n [k,m,g] is the maximum size of the backing-store file.
Caution – Caution –
If the backing-store file runs out of space, the snapshot might delete itself, which causes the backup to fail. Check the /var/adm/messages file for possible snapshot errors.
For more information, see the fssnap_ufs(1M) man page.
ProcedureHow to Create a UFS Snapshot
Steps
  1. Become superuser or assume an equivalent role.
  2. Make sure that the file system has enough disk space for the backing-store file.
    # df -k
  3. Make sure that a backing-store file of the same name and location does not already exist.
    # ls /backing-store-file
  4. Create the UFS snapshot.
    # fssnap -F ufs -o bs=/backing-store-file /file-system
    Note –
    The backing-store file must reside on a different file system than the file system that is being captured using UFS snapshots.
  5. Verify that the snapshot has been created.
    # /usr/lib/fs/ufs/fssnap -i /file-system
Example 24–1 Creating a UFS Snapshot
The following example shows how to create a snapshot of the /usr file system. The backing-store file is /scratch/usr.back.file. The virtual device is /dev/fssnap/1.
# fssnap -F ufs -o bs=/scratch/usr.back.file /usr
/dev/fssnap/1
The following example shows how to limit the backing-store file to 500 Mbytes.
# fssnap -F ufs -o maxsize=500m,bs=/scratch/usr.back.file /export/home
/dev/fssnap/1
ProcedureHow to Display UFS Snapshot Information
You can display the current snapshots on the system by using the fssnap -i option. If you specify a file system, you see detailed information about that snapshot. If you don't specify a file system, you see information about all of the current UFS snapshots and their corresponding virtual devices.
Note –
Use the UFS file system-specific fssnap command to view the extended snapshot information as shown in the following examples.
Steps
  2. List all current snapshots:
    For example:
    Snapshot number               : 0
    Block Device                  : /dev/fssnap/0
    Raw Device                    : /dev/rfssnap/0
    Mount point                   : /usr
    Device state                  : idle
    Backing store path            : /var/tmp/snapshot3
    Backing store size            : 256 KB
    Maximum backing store size    : Unlimited
    Snapshot create time          : Wed Oct 08 10:38:25 2003
    Copy-on-write granularity     : 32 KB
    Snapshot number               : 1
    Block Device                  : /dev/fssnap/1
    Raw Device                    : /dev/rfssnap/1
    Mount point                   : /
    Device state                  : idle
    Backing store path            : /tmp/bs.home
    Backing store size            : 448 KB
    Snapshot create time          : Wed Oct 08 10:39:29 2003
  3. Display detailed information about a specific snapshot:
    For example:
    # /usr/lib/fs/ufs/fssnap -i /usr
    Snapshot number               : 0
    Mount point                   : /usr
    Device state                  : idle
Deleting a UFS Snapshot
When you create a UFS snapshot, you can specify that the backing-store file is unlinked. An unlinked backing-store file is removed after the snapshot is deleted. If you don't specify the -o unlink option when you create a UFS snapshot, you must delete the backing-store file manually.
The backing-store file occupies disk space until the snapshot is deleted, whether you use the -o unlink option to remove the backing-store file or you delete the file manually.
ProcedureHow to Delete a UFS Snapshot
You can delete a snapshot either by rebooting the system or by using the fssnap -d command. When you use this command, you must and specify the path of the file system that contains the UFS snapshot.
Steps
  2. Identify the snapshot to be deleted.
  3. Delete the snapshot.
    # fssnap -d /file-system
    Deleted snapshot 1.
  4. (Optional) If you did not use the -o unlink option when you created the snapshot, manually delete the backing-store file.
    # rm /file-system/backing-store-file
Example 24–2 Deleting a UFS Snapshot
The following example shows how to delete a snapshot and assumes that the -o unlink option was not used.
# fssnap -i
    0    /    1    /usr
# fssnap -d /usr
 Deleted snapshot 1.
# rm /scratch/usr.back.file
Backing Up a UFS Snapshot
You can create a full backup or an incremental backup of a UFS snapshot. You can use the standard Solaris backup commands to back up a UFS snapshot.
The virtual device that contains the UFS snapshot acts as a standard read-only device. So, you can back up the virtual device as if you were backing up a file system device.
If you are using the ufsdump command to back up a UFS snapshot, you can specify the snapshot name during the backup. See the following procedure for more information.
ProcedureHow to Create a Full Backup of a UFS Snapshot (ufsdump)
Steps
  2. Identify the UFS snapshot to be backed up.
    For example:
    Snapshot number               : 0
    Mount point                   : /usr
    Device state                  : idle
  3. Back up the UFS snapshot.
    # ufsdump 0ucf /dev/rmt/0 /snapshot-name
    For example:
    # ufsdump 0ucf /dev/rmt/0 /dev/rfssnap/1
  4. Verify that the snapshot is backed up.
    For example:
    # ufsrestore tf /dev/rmt/0
ProcedureHow to Create an Incremental Backup of a UFS Snapshot (ufsdump)
Backing up a UFS snapshot incrementally means that only the files that have been modified since the last snapshot are backed up. Use the ufsdump command with the new N option. This option specifies the file system device name to be inserted into the /etc/dumpdates file for tracking incremental dumps.
The following ufsdump command specifies an embedded fssnap command to create an incremental backup of a file system.
Steps
  2. Create an incremental backup of a UFS snapshot.
    For example:
    # ufsdump 1ufN /dev/rmt/0 /dev/rdsk/c0t1d0s0 `fssnap -F ufs -o raw,bs=
    /export/scratch,unlink /dev/rdsk/c0t1d0s0`
    In this example, the -o raw option is used to display the name of the raw device instead of the block device. By using this option, you make it easier to embed the fssnap command in commands (such as the ufsdump command) that require the raw device instead.
  3. Verify that the snapshot is backed up.
    # ufsrestore ta /dev/rmt/0
ProcedureHow to Back Up a UFS Snapshot (tar)
If you are using the tar command to back up the snapshot, mount the snapshot before backing it up.
Steps
  2. Create a mount point for the snapshot.
    For example:
    # mkdir /backups/home.bkup
  3. Mount the snapshot.
    # mount -F ufs -o ro /dev/fssnap/1 /backups/home.bkup
  4. Change to the mounted snapshot directory.
    # cd /backups/home.bkup
  5. Back up the snapshot with the tar command.
    # tar cvf /dev/rmt/0 .
Restoring Data From a UFS Snapshot Backup
The backup created from the virtual device is essentially just a backup of what the original file system looked like when the snapshot was taken. When you restore a file system from the backup, restore as if you had taken the backup directly from the original file system. Such a restore uses the ufsrestore command. For information on using the ufsrestore command to restore a file or file system, see Chapter 25, Restoring Files and File Systems (Tasks).
