System Administration Guide: Devices and File Systems
x86: Troubleshooting PCI Configuration Problems
Error Message
cfgadm: Configuration operation invalid: invalid transition
Cause
An invalid transition was attempted.
Solution
Check whether the cfgadm -c command was issued appropriately. Use the cfgadm command to check the current receptacle and occupant state and to make sure that the Ap_Id is correct.
Error Message
cfgadm: Attachment point not found
Cause
The specified attachment point was not found.
Solution
Check whether the attachment point is correct. Use the cfgadm command to display a list of available attachment points. Also check the physical path to see if the attachment point is still there.
Note –
In addition to the cfgadm command, several other commands are helpful during hot-pluggable operations. The prtconf command displays whether Solaris recognizes the hardware. After adding hardware, use the prtconf command to verify that the hardware is recognized. After a configure operation, use the prtconf -D command to verify that the driver is attached to the newly installed hardware device.
