This section describes USB driver enhancements in this Solaris release.
New generic USB driver – USB devices can now be accessed and manipulated by applications using standard UNIX® read(2) and write(2) system calls, and without writing a special kernel driver. Additional features include:
Applications have access to raw device data and device status.
Supports control, bulk, and interrupt (in and out) transfers.
For more information, refer to the ugen(7D) man page and the USB DDK at: http://developers.sun.com/solaris/developer/support/driver/usb.html
Digi Edgeport USB support – Provides support for several Digi Edgeport USB to serial port converter devices.
New devices are accessed as /dev/term/[0-9]* and /dev/cua/[0-9]*.
USB serial ports are usable as any other serial port would be, except that they cannot serve as a local serial console. The fact that their data is run through a USB port is transparent to the user.
For more information, see usbser_edge(7D), or go to http://www.digi.com and http://www.sun.com/io.
Documentation and binary support for user-written kernel and userland drivers – A Solaris USB Driver Development Kit (DDK) is available. For up-to-date information on USB driver development, including information on the DDK, go to: http://developers.sun.com/solaris/developer/support/driver/usb.html
Features of the EHCI driver include:
Complies with enhanced host controller interface that supports USB 2.0.
Supports high-speed control, bulk, and interrupt transfers.
Currently, there is no support for high-speed isochronous transactions. For example, USB 2.0 audio devices are not supported.
If there are USB 2.0 and USB 1.x devices on the system, the EHCI and OHCI drivers hand-off device control depending upon the type of device that is connected to the system.
The USB 2.0 PCI card has one EHCI controller and one or more OHCI controllers.
A USB 1.1 device is dynamically assigned to the OHCI controller when it is plugged in. A USB 2.0 device is dynamically assigned to the EHCI controller when it is plugged in.
