System Administration Guide: Devices and File Systems
Chapter 8 Using USB Devices (Tasks)
This chapter provides step-by-step instructions for using USB devices in the Solaris environment.
For information on the procedures associated with using USB devices, see the following:
For overview information about using USB devices, see Chapter 7, Using USB Devices (Overview).
Managing USB Devices in the Solaris Environment (Roadmap)
Use this map to identify all the tasks for managing USB devices in the Solaris environment. Each task points to a series of additional tasks such as using USB devices, hot-plugging USB devices, or adding USB audio devices.
Task
Description
For Instructions
Using USB devices
USB devices must be formatted before file systems can be created and mounted.
Using USB Mass Storage Devices (Task Map)
Hot-plug USB devices
Dynamically add or remove USB devices from your system.
You can physically add or remove USB devices to and from your system.
Hot-Plugging USB Devices (Task Map)
Physically or logically add or remove USB devices to and from your system with the cfgadm command.
Hot-Plugging USB Devices With the cfgadm Command (Task Map)
Add USB audio devices
Use this map to identify tasks associated with adding USB audio devices.
Using USB Audio Devices (Task Map)
Task
Description
For Instructions
Prepare to use a USB mass storage device
Prepare to use a USB mass storage device with vold running.
Preparing to Use a USB Mass Storage Device With vold Running
Prepare to use a USB mass storage device without vold running.
How to Prepare to Use USB Mass Storage Devices Without vold Running
Display USB device information
Use the prtconf command to display information about USB devices.
How to Display USB Device Information (prtconf)
Format a USB mass storage device
Format a USB mass storage device so that you can put data on it.
How to Format a USB Mass Storage Device Without vold Running
Mount a USB mass storage device
Mount a USB mass storage device with vold running.
How to Mount or Unmount a USB Mass Storage Device With vold Running
Mount a USB mass storage device without vold running.
How to Mount or Unmount a USB Mass Storage Device Without vold Running
(Optional) Disable USB device drivers
Disable USB device drivers if you do not want the USB support on your system.
(Optional) Remove unused USB device links
Remove unused USB device links with the devfsadm command.
How to Remove Unused USB Device Links
Note –
For up-to-date information on using USB mass storage devices in this Solaris release, see USB Mass Storage Devices.
Starting in the Solaris 9 release, removable mass storage devices such as USB CD-RWs, hards disks, DVDs, digital cameras, Zip, Peerless, SmartMedia, CompactFlash, ORB, and USB diskette devices are supported.
For a complete list of USB devices that are supported in the Solaris environment, see http://www.sun.com/io_technologies/USB.html.
These devices can be managed with or without volume management. For information on managing devices with volume management, see vold(1M).
Using USB Diskette Devices
USB diskette devices appear as removable media devices like other USB devices. USB diskette devices are not managed by the fd (floppy) driver. Applications that issue ioctl(2) calls intended for the fd (native floppy) driver will fail. Applications that issue only read(2) and write(2) calls will succeed. Other applications, such as SunPCI and rmformat, will also succeed.
Note –
CDE's File Manager does not fully support USB diskettes at this time. However, you can open, rename, and format diskettes that contain a UFS file system from File Manager's Removable Media Manager. You can only open diskettes that contain a PCFS file system from the Removable Media Manager. If a diskette contains either type of file system, you can successfully drag and drop files between the diskette and File Manager.
Volume management (vold) sees the USB diskette device as a SCSI removable media device. Volume management makes the device available for access under the /rmdisk directory.
For more information on how to use USB diskette devices, see Chapter 1, Managing Removable Media (Overview).
Using Non-Compliant USB Mass Storage Devices
Some devices might be supported by the USB mass storage driver even though they do not identify themselves as compliant with the USB mass storage class or identify themselves incorrectly. The scsa2usb.conf file contains an attribute-override-list that lists the vendor ID, product ID, and revision for matching mass storage devices, as well as fields for overriding the default device attributes. The entries in this list are commented out by default, and can be copied and uncommented to enable support of particular devices.
If you connect a USB mass storage device to a system running this Solaris release and the system is unable to use it, you can check the /kernel/drv/scsa2usb.conf file to see if there is a matching, commented entry for this device. Follow the information given in the scsa2usb.conf file to see if a particular device can be supported by using the override information. For a listing of recommended USB mass storage devices, go to http://www.sun.com/io_technologies/USB.html.
For more information, see scsa2usb(7D).
If you are running the Solaris Common Desktop Environment (CDE), USB removable mass storage devices are managed by the Removable Media Manager component of the CDE File Manager. For more information on the CDE File Manager, see dtfile(1).
Note –
You must include the /usr/dt/man directory in your MANPATH variable to display the man pages that are listed in this section. You must also have the /usr/dt/bin directory in your path and have CDE running to use these commands, or have a DISPLAY variable set to use these commands remotely.
The following table identifies the commands that Removable Media Manager uses to manage storage devices from the CDE environment.
Command
Man Page
Task
sdtmedia_format
sdtmedia_format(1)
Format and label a device
sdtmedia_prop
sdtmedia_prop(1)
Display properties of a device
sdtmedia_prot
sdtmedia_prot(1)
Change device protection
sdtmedia_slice
sdtmedia_slice(1)
Create or modify slices on a device
After the USB device is formatted, it is usually mounted under the /rmdisk/label directory. For more information on configuring removable storage devices, see rmmount.conf(4) or vold.conf(4).
The device nodes are created under the /vol/dev directory. For more information, see scsa2usb(7D).
The following procedures describe how to manage USB mass storage devices without vold running. The device nodes are created under the /dev/rdsk directory for character devices and under the /dev/dsk directory for block devices. Device links are created when the devices are hot-plugged. For more information, see scsa2usb(7D).
ProcedureHow to Prepare to Use USB Mass Storage Devices Without vold Running
You can use USB mass storage devices without the volume management (vold) running. Stop vold by issuing the following command:
# /etc/init.d/volmgt stop
Or, use the following procedure to keep vold running, but do not register the USB mass storage devices with vold.
Steps
  1. Become superuser.
  2. Remove volume manager registration of USB mass storage devices by commenting the following line in the /etc/vold.conf file, like this:
    # use rmdisk drive /dev/rdsk/c*s2 dev_rmdisk.so rmdisk%d
  3. After this line is commented, restart vold.
    # /etc/init.d/volmgt start
    Caution – Caution –
    If you comment out this line and other SCSI or ATAPI Zip, Peerless or other removable devices are in the system, vold registration for these devices would be disabled as well.
    For more information, see vold.conf(4).
$ prtconf
        usb, instance #0
                 hub, instance #2
                     device, instance #8
                         interface (driver not attached)
                     printer (driver not attached)
                     mouse, instance #14
                     device, instance #9
                         keyboard, instance #15
                         mouse, instance #16
                     storage, instance #7
                         disk (driver not attached)
                     communications, instance #10
                         modem (driver not attached)
                         data (driver not attached)
                 storage, instance #0
                 storage, instance #1
You can use the prtconf command's -D option to display additional driver information. This information can be used to tell which ports and devices are being driven by the USBA 1.0 framework on SPARC systems, as displayed in the following example:
$ prtconf -D
SUNW,Sun-Blade-1500
1 pci, instance #0 (driver name: pcisch)
           isa, instance #0 (driver name: ebus)
2 usb, instance #0 (driver name: ohci)
           usb, instance #1 (driver name: ohci)
3 pci, instance #0 (driver name: pci_pci)
4 usb, instance #0 (driver name: usba10_ohci)
            usb, instance #1 (driver name: usba10_ohci)
            usb, instance #0 (driver name: usba10_ehci)
                storage, instance #9 (driver name: usba10_scsa2usb)
                    disk, instance #9 (driver name: usb_sd)
            firewire, instance #0 (driver name: hci1394)
In the output above, note the following configuration characteristics:
ProcedureHow to Format a USB Mass Storage Device Without vold Running
USB mass storage devices, as all others used by the Solaris operating system, must be formatted and contain a file system before they can be used. USB mass storage devices, including diskettes, support both PCFS and UFS file systems. Be sure the disk is formatted before putting either a PCFS or UFS file system on it.
Steps
  1. See How to Prepare to Use USB Mass Storage Devices Without vold Running for information on disabling vold.
  2. (Optional) Add the USB diskette device to your system.
    For information on hot-plugging USB devices, see:
  3. (Optional) Identify the diskette device.
    For example:
    # cd /dev/rdsk
    # devfsadm -C
    # ls -l c*0 | grep usb
    lrwxrwxrwx   1 root  root   55 Mar  5 10:35 c2t0d0s0 ->
    ../../devices/pci@1f,0/usb@c,3/storage@3/disk@0,0:a,raw
    In this example, the diskette device is c2t0d0s0.
  4. Insert a diskette into the diskette drive.
  5. Format the diskette.
    % rmformat -Flong raw-device
    For example:
    % rmformat -Flong /dev/rdsk/c2t0d0s0
  6. Determine the file system type and select one of the following:
    1. Create a PCFS file system.
      # mkfs -F pcfs -o nofdisk,size=size raw-device
      Specify the -size option in 512–byte blocks.
      The following example shows how to create a PCFS file system on a 1.4 Mbyte diskette.
      # mkfs -F pcfs -o nofdisk,size=2880 /dev/rdsk/c4t0d0s0
      The following example shows how to create a UFS file system on a 100 Mbyte Zip drive.
      # mkfs -F pcfs -o nofdisk,size=204800 /dev/rdsk/c5t0d0s0
      This command can take several minutes to complete.
    2. Create a UFS file system.
      # newfs raw-device
      For example:
      # newfs /dev/rdsk/c4t0d0s0
      Note –
      UFS file system overhead consumes a significant portion of space on a diskette, due to a diskette's limited storage capacity.
ProcedureHow to Mount or Unmount a USB Mass Storage Device With vold Running
Steps
  1. Display device aliases for all removable mass storage devices, including USB mass storage devices.
    $ eject -n
    cdrom0 -> /vol/dev/rdsk/c0t6d0/audio_cd   (Generic CD device)
    zip0 -> /vol/dev/rdsk/c1t0d0/zip100       (USB Zip device)
    zip1 -> /vol/dev/rdsk/c2t0d0/fat32        (USB Zip device)
    rmdisk0 -> /vol/dev/rdsk/c5t0d0/unnamed_rmdisk (Peerless, HD or floppy)
    rmdisk1 -> /vol/dev/rdsk/c4t0d0/clik40    (Generic USB storage)
  2. Select one of the following to mount or unmount a USB mass storage device.
    1. Mount a USB mass storage device by using the device aliases listed previously.
      $ volrmmount -i device-alias
      This example shows how to mount a USB Zip drive (/rmdisk/zip0).
      $ volrmmount -i zip0
    2. Unmount a USB mass storage device.
      $ volrmmount -e device-alias
      This example shows how to unmount a USB Zip drive (/rmdisk/zip0).
      $ volrmmount -e zip0
  3. Eject a USB device from a generic USB drive.
    $ eject device-alias
    For example:
    $ eject rmdisk0
    Note –
    The eject command also unmounts the device if the device is not unmounted already. The command also terminates any active applications that access the device.
ProcedureHow to Mount or Unmount a USB Mass Storage Device Without vold Running
Steps
  2. Become superuser.
    For example:
    # cd /dev/rdsk
    # devfsadm -C
  4. Select one of the following to mount or unmount a USB mass storage device.
    1. Mount a USB mass storage device.
      # mount [ -F fstype ] block-device mount-point
      This example shows how to mount a device with a UFS file system.
      # mount /dev/dsk/c1t0d0s2 /mnt
      This example shows how to mount a device with a PCFS file system.
      # mount -F pcfs /dev/dsk/c1t0d0s0:c /mnt
      This example shows how to mount a CD with a read-only HSFS file system.
      # mount -F hsfs -o ro /dev/dsk/c1t0d0s2 /mnt
      First, be sure no one is using the file system on the device.
      For example:
      # fuser -c -u /mnt
      # umount /mnt
    3. Eject the device.
      # eject /dev/[r]dsk/cntndnsn
      For example:
      # eject /dev/rdsk/c1t0d0s2
Disabling Specific USB Drivers
You can disable specific types of USB devices by disabling their client driver. For example, USB printers can be disabled by disabling the usbprn driver that directs them. Disabling usbprn does not affect other kinds of devices, such as USB storage devices.
Be careful that device types are disabled on both frameworks. You cannot disable device types on one framework only. The following table identifies some USB device types and their corresponding drivers.
Device Type
Driver to Disable
audio
usb_ac and usb_as
HID (usually keyboard and mouse
hid
storage
scsa2usb
printer
usbprn
serial
usbser_edge
If you disable a driver for a USB device that is still connected to the system, you will see a console message similar to the following:
usba10: WARNING: usba:    no driver found for device name
ProcedureHow to Disable Specific USB Drivers
Steps
  2. Record the driver aliases that you are about to remove.
    # cp /etc/driver_aliases /etc/driver_aliases.orig
  3. Identify the specific USB driver alias name.
    For example:
    # grep usbprn /etc/driver_aliases
    usbprn "usbif,class7.1.1"
    usbprn "usbif,class7.1.2"
  4. Remove the driver alias entry.
    For example:
    # update_drv -d -i '"usbif,class7.1.1"' usbprn
    # update_drv -d -i '"usbif,class7.1.2"' usbprn
  5. Reboot the system.
    # init 6
ProcedureHow to Remove Unused USB Device Links
Use this procedure if a USB device is removed while the system is powered off. It is possible that removing the USB device while the system is powered off will leave device links for devices that do not exist.
Steps
  2. Close all applications that might be accessing the device.
  3. Remove the unused links for a specific USB class.
    For example:
    # devfsadm -C -c audio
    Or, just remove the dangling links:
    # devfsadm -C
Task
Description
For Instructions
Add a USB mass storage device
Add a USB mass storage device with vold running.
How to Add a USB Mass Storage Device With vold Running
Add a USB mass storage device without vold running.
How to Add a USB Mass Storage Device Without vold Running
Remove a USB mass storage device
Remove a USB mass storage device with vold running.
How to Remove a USB Mass Storage Device With vold Running
Remove a USB mass storage device without vold running.
How to Remove a USB Mass Storage Device Without vold Running
Add a USB camera
Add a USB camera to access digital images.
How to Add a USB Camera
Hot-plugging a device means the device is added or removed without shutting down the operating system or powering off the system. All USB devices are hot-pluggable.
When you hot-plug a USB device, the device is immediately seen in the system's device hierarchy, as displayed in the prtconf command output. When you remove a USB device, the device is removed from the system's device hierarchy, unless the device is in use.
If the USB device is in use when it is removed, the hot-plug behavior is a little different. If a device is in use when it is unplugged, the device node remains, but the driver controlling this device stops all activity on the device. Any new I/O activity issued to this device is returned with an error.
In this situation, the system prompts you to plug in the original device. If the device is no longer available, stop the applications. After a few seconds, the port will become available again.
Note –
Data integrity might be impaired if you remove an active or open device. Always close the device before removing, except the console keyboard and mouse, which can be moved while active.
ProcedureHow to Add a USB Mass Storage Device With vold Running
This procedure describes how to add a USB device with vold running.
Steps
  1. Connect the USB mass storage device.
  2. Instruct vold to scan for new devices.
    # touch /etc/vold.conf
  3. Restart vold.
    # pkill -HUP vold
  4. Verify that the device has been added.
    $ ls device-alias
    For more information on volume management device names, see Chapter 1, Managing Removable Media (Overview).
ProcedureHow to Add a USB Mass Storage Device Without vold Running
This procedure describes how to add a USB device without vold running.
Steps
  1. If needed, see How to Prepare to Use USB Mass Storage Devices Without vold Running for information on disabling vold.
  2. Connect the USB mass storage device.
  3. Verify that the USB device has been added.
    Locate the USB disk device links, which may be among device links of non-USB storage devices, as follows:
    $ cd /dev/rdsk
    $ ls -l c*0 | grep usb
    lrwxrwxrwx   1 root     root          67 Apr 30 15:12 c1t0d0s0 ->
    	../../devices/pci@1f,0/pci@5/pci@0/usb@8,2/storage@1/disk@0,0:a,raw
ProcedureHow to Remove a USB Mass Storage Device With vold Running
The following procedure uses a Zip drive as an example of removing a USB device with vold running.
Steps
  1. Stop any active applications that are using the device.
  2. Unmount the device.
    For example:
    For example:
    $ eject zip0
  4. Become superuser and stop vold.
  5. Remove the USB mass storage device.
  6. Start vold.
ProcedureHow to Remove a USB Mass Storage Device Without vold Running
This procedure describes how to remove a USB device without vold running.
Steps
  3. Stop any active applications that are using the device.
  4. Remove the USB device.
    1. Unmount the device.
      For example:
      # umount /mnt
    2. Remove the device.
ProcedureHow to Add a USB Camera
Use this procedure to add a USB camera.
Steps
  2. Plug in and turn on the USB camera.
    The system creates a logical device for the camera. After the camera is plugged in, output is written to the /var/adm/messages file to acknowledge the device's connection. The camera is seen as a storage device to the system.
  3. Examine the output that is written to the /var/adm/messages file.
    Examining this output enables you to determine which logical device was created so that you can then use that device to access your images. The output will look similar to the following:
    # more /var/adm/messages
    Jul 15 09:53:35 buffy usba: [ID 349649 kern.info]    OLYMPUS, C-3040ZOOM,
     000153719068
    Jul 15 09:53:35 buffy genunix: [ID 936769 kern.info] scsa2usb1 is
    /pci@0,0/pci925,1234@7,2/storage@2
    Jul 15 09:53:36 buffy scsi: [ID 193665 kern.info] sd3 at scsa2usb1:
    target 0 lun 0
    Match the device with a mountable /dev/dsk link entry, by doing the following:
    # ls -l /dev/dsk/c*0 | grep /pci@0,0/pci925,1234@7,2/storage@2
     lrwxrwxrwx   1 root     root          58 Jul 15  2002 c3t0d0p0 ->
     ../../devices/pci@0,0/pci925,1234@7,2/storage@2/disk@0,0:a
  4. Mount the USB camera file system.
    The camera's file system is most likely a PCFS file system. In order to mount the file system on the device created, the slice that represents the disk must be specified. The slice is normally s0 for a SPARC system, and p0 for an x86 system.
    For example, to mount the file system on an x86 system, execute the following command:
    # mount -F pcfs /dev/dsk/c3t0d0p0:c /mnt
    To mount the file system on a SPARC system, execute the following command:
    # mount -F pcfs /dev/dsk/c3t0d0s0:c /mnt
    For information on mounting file systems, see Chapter 17, Mounting and Unmounting File Systems (Tasks).
    For information on mounting different PCFS file systems, see mount_pcfs(1M).
  5. Verify that the image files are available.
    For example:
    # ls /mnt/DCIM/100OLYMP/
    P7220001.JPG*  P7220003.JPG*  P7220005.JPG*
    P7220002.JPG*  P7220004.JPG*  P7220006.JPG*
  6. View and manipulate the image files created by the USB camera.
    # /usr/dt/bin/sdtimage P7220001.JPG &
  7. Unmount the file system before disconnecting the camera.
    For example:
    # umount /mnt
  8. Turn off and disconnect the camera.
Task
Description
For Instructions
Add a USB microphone and speakers.
How to Add USB Audio Devices
Identify your system's primary audio device
Identify which audio device is your primary audio device.
How to Identify Your System's Primary Audio Device
Change the primary USB audio device
You might want to make one particular audio device the primary audio device if you remove or change your USB audio devices.
How to Change the Primary USB Audio Device
If you remove a USB audio device while the system is powered off, the /dev/audio device might be pointing to a /dev/sound/* device that doesn't exist.
Solve USB audio problems
Use this section if no sound comes from the USB speakers.
Solving USB Audio Problems
This Solaris release provides USB audio support that is implemented by a pair of cooperating drivers, usb_ac and usb_as. The audio control driver, usb_ac, is a USBA (Solaris USB Architecture) compliant client driver that provides the controlling interface to user applications. The audio streaming driver, usb_as, is provided to process audio data messages during play and record. It sets sample frequency and precision, and encodes requests from the usb_ac driver. Both drivers comply to the USB audio class 1.0 specification.
Some audio devices can set volume under software control. A STREAMS module, usb_ah, is pushed on top of the HID driver for managing this function.
Solaris supports USB audio devices that are play-only, record-only, or record and play. Hot-plugging of USB audio devices is supported.
The primary audio device is /dev/audio. You can verify that /dev/audio is pointing to USB audio by using the following command:
% mixerctl
Device /dev/audioctl:
  Name    = USB Audio
  Version = 1.0
  Config  = external
Audio mixer for /dev/audioctl is enabled
After you connect your USB audio devices, you access them with the audioplay and audiorecord command through the /dev/sound/N device links.
Note that the /dev/audio and /dev/sound/N devices can refer to speakers, microphones, or combo devices. If you refer to the incorrect device type, the command will fail. For example, the audioplay command will fail if you try to use it with a microphone.
You can select a specific default audio device for most Sun audio applications, such as audioplay and audiorecord, by setting the AUDIODEV shell variable or by specifying the -d option for these commands. However, setting AUDIODEV does not work for third-party applications that have /dev/audio hardcoded as the audio file.
When you plug in a USB audio device, it automatically becomes the primary audio device, /dev/audio, unless /dev/audio is in use. For instructions on changing /dev/audio from onboard audio to USB audio and vice versa, refer to How to Change the Primary USB Audio Device, and usb_ac(7D).
Hot-Plugging Multiple USB Audio Devices
If a USB audio device is plugged into a system, it becomes the primary audio device, /dev/audio. It remains the primary audio device even after the system is rebooted. If additional USB audio devices are plugged in, the last one becomes the primary audio device.
For additional information on troubleshooting USB audio device problems, see usb_ac(7D).
ProcedureHow to Add USB Audio Devices
Use the following procedure to add USB audio devices.
Steps
  1. Plug in the USB speaker.
    The primary audio device, /dev/audio, points to the USB speaker.
    % ls -l /dev/audio
    lrwxrwxrwx   1 root     root    10 Feb 13 08:46 /dev/audio -> usb/audio0
  2. (Optional) Remove the speaker. Then plug it back in.
    If you remove the speaker, the /dev/audio device reverts back to onboard audio.
    % ls -l /dev/audio
    lrwxrwxrwx   1 root     root   7 Feb 13 08:47 /dev/audio -> sound/0
  3. Add a USB microphone.
    % ls -l /dev/audio
    lrwxrwxrwx   1 root     root    10 Feb 13 08:54 /dev/audio -> usb/audio1
ProcedureHow to Identify Your System's Primary Audio Device
This procedure assumes that you have already connected the USB audio devices.
Step
    Examine your system's new audio links.
    For example:
    % ls -lt /dev/audio*
    lrwxrwxrwx   1 root     root      7 Jul 23 15:46 /dev/audio -> usb/audio0
    lrwxrwxrwx   1 root     root     10 Jul 23 15:46 /dev/audioctl ->
    usb/audioctl0/
    % ls -lt /dev/sound/*
    lrwxrwxrwx   1 root     root     74 Jul 23 15:46 /dev/sound/1 ->
    ../../devices/pci@1f,4000/usb@5/hub@1/device@3/sound-control@0:sound,a...
    lrwxrwxrwx   1 root     root     77 Jul 23 15:46 /dev/sound/1ctl ->
    lrwxrwxrwx   1 root     other    66 Jul 23 14:21 /dev/sound/0 ->
    ../../devices/pci@1f,4000/ebus@1/SUNW,CS4231@14,200000:sound,audio
    lrwxrwxrwx   1 root     other    69 Jul 23 14:21 /dev/sound/0ctl ->
    ../../devices/pci@1f,4000/ebus@1/SUNW,CS4231@14,200000:sound,audioctl
    Notice that the primary audio device, /dev/audio, is pointing to the newly plugged in USB audio device, /dev/usb/audio0.
    You can also examine your system's USB audio devices with the prtconf command and look for the USB device information.
    % prtconf
    usb, instance #0
       hub, instance #0
            mouse, instance #0
            device, instance #0
                sound-control, instance #0
                sound, instance #0
                input, instance #0
Troubleshooting USB Audio Device Problems
This section describes how to troubleshoot USB audio device problems.
Sometimes USB speakers do not produce any sound even though the driver is attached and the volume is set to high. Hot-plugging the device might not change this behavior.
The workaround is to power cycle the USB speakers.
Key Points of Audio Device Ownership
Keep the following key points of audio device ownership in mind when working with audio devices.
Task
Description
For Instructions
Display USB bus information
Display information about USB devices and buses.
How to Display USB Bus Information (cfgadm)
Unconfigure a USB device
Logically unconfigure a USB device that is still physically connected to the system.
How to Unconfigure a USB Device
Configure a USB device
Configure a USB device that was previously unconfigured.
How to Configure a USB Device
Logically disconnect a USB device
You can logically disconnect a USB device if you are not physically near the system.
How to Logically Disconnect a USB Device
Logically connect a USB device
Logically connect a USB device that was previously logically disconnected or unconfigured.
How to Logically Connect a USB Device
Disconnect a USB device subtree
Disconnect a USB device subtree, which is the hierarchy (or tree) of devices below a hub.
How to Logically Disconnect a USB Device Subtree
Reset a USB device
Reset a USB device to logically remove and recreate the device.
How to Reset a USB Device
Change the default configuration of a multi-configuration USB device
Change the default configuration of a multi-configuration USB device.
How to Change the Default Configuration of a Multi-Configuration USB Device
You can add and remove a USB device from a running system without using the cfgadm command. However, a USB device can also be logically hot-plugged without physically removing the device. This scenario is convenient when you are working remotely and you need to disable or reset a non-functioning USB device. The cfgadm command also provides a way to display the USB device tree including manufacturer and product information.
The cfgadm command displays information about attachment points, which are locations in the system where dynamic reconfiguration operations can occur. An attachment point consists of:
Attachment points are represented by logical and physical attachment point IDs (Ap_Ids). The physical Ap_Id is the physical pathname of the attachment point. The logical Ap_Id is a user-friendly alternative for the physical Ap_Id. For more information on Ap_Ids, see cfgadm_usb(1M).
The cfgadm command provides the following USB device status information.
Receptacle State
Description
empty/unconfigured
The device is not physically connected.
disconnected/unconfigured
The device is logically disconnected and unavailable, even though the device could still be physically connected.
The device is logically connected, but unavailable. The device is visible in prtconf output.
connected/configured
The device is connected and available.
The following sections describe how to hot-plug a USB device through the software with the cfgadm command. All of the sample USB device information in these sections has been truncated to focus on relevant information.
Use the cfgadm command to display USB bus information. For example:
% cfgadm
Ap_Id                       Type         Receptacle   Occupant     Condition
usb0/4.5                    usb-hub      connected    configured   ok
usb0/4.5.1                  usb-device   connected    configured   ok
usb0/4.5.2                  usb-printer  connected    configured   ok
usb0/4.5.3                  usb-mouse    connected    configured   ok
usb0/4.5.4                  usb-device   connected    configured   ok
usb0/4.5.5                  usb-storage  connected    configured   ok
usb0/4.5.6                  usb-communi  connected    configured   ok
usb0/4.5.7                  unknown      empty        unconfigured ok
usb0/4.6                    usb-storage  connected    configured   ok
usb0/4.7                    usb-storage  connected    configured   ok
In the preceding example, usb0/4.5.1 identifies a device connected to port 1 of the second-level external hub, which is connected to port 5 of first-level external hub, which is connected to the first USB controller's root hub, port 4.
Use the following cfgadm command to display specific USB device information. For example:
% cfgadm -l -s "cols=ap_id:info"
Ap_Id       Information
 usb0/4.5.1  Mfg: Inside Out Networks Product: Edgeport/421 NConfigs: 1
Config: 0  : ...
 usb0/4.5.2  Mfg: <undef> Product: <undef>   NConfigs: 1 Config: 0 ...
 usb0/4.5.3  Mfg: Mitsumi Product: Apple USB Mouse NConfigs: 1 Config: 0 ...
 usb0/4.5.4  Mfg: NMB  Product: NMB USB KB/PS2 M NConfigs: 1 Config: 0
 usb0/4.5.5  Mfg: Hagiwara Sys-Com  Product: SmartMedia R/W  NConfigs: 1
Config: 0 : ...
 usb0/4.5.6  Mfg: 3Com Inc.  Product: U.S.Robotics 56000 Voice USB Modem
NConfigs: 2 ...
 usb0/4.5.7
 usb0/4.6    Mfg: Iomega  Product: USB Zip 250  NConfigs: 1  Config: 0
 : Default
 usb0/4.7    Mfg: Iomega  Product: USB Zip 100  NConfigs: 1  Config: 0
 : Default
For examples of using the prtconf command to display USB configuration information, see How to Display USB Device Information (prtconf).
ProcedureHow to Unconfigure a USB Device
You can unconfigure a USB device that is still physically connected to the system, but a driver will never attach to it. Note that a USB device remains in the prtconf output even after that device is unconfigured.
Steps
  2. Unconfigure the USB device.
    # cfgadm -c unconfigure usb0/4.7
    Unconfigure the device: /devices/pci@8,700000/usb@5,3/hub@4:4.7
    This operation will suspend activity on the USB device
    Continue (yes/no)? y
  3. Verify that the device is unconfigured.
    # cfgadm
    usb0/4.7                 usb-storage  connected    unconfigured ok
ProcedureHow to Configure a USB Device
Steps
  2. Configure a USB device.
    # cfgadm -c configure usb0/4.7
  3. Verify that the USB device is configured.
    # cfgadm usb0/4.7
ProcedureHow to Logically Disconnect a USB Device
If you want to remove a USB device from the system and the prtconf output, but you are not physically near the system, just logically disconnect the USB device. The device is still physically connected, but it is logically disconnected, unusable, and not visible to the system.
Steps
  2. Disconnect a USB device.
    # cfgadm -c disconnect -y usb0/4.7
  3. Verify that the device is disconnected.
    # cfgadm usb0/4.7
    usb0/4.7               unknown   disconnected  unconfigured  ok
ProcedureHow to Logically Connect a USB Device
Use this procedure to logically connect a USB device that was previously logically disconnected or unconfigured.
Steps
  2. Connect a USB device.
  3. Verify that the device is connected.
    # cfgadm usb0/4.7
    The device is now available and visible to the system.
ProcedureHow to Logically Disconnect a USB Device Subtree
Use this procedure to disconnect a USB device subtree, which is the hierarchy (or tree) of devices below a hub.
Steps
  2. Remove a USB device subtree.
  3. Verify that the USB device subtree is disconnected.
    # cfgadm usb0/4
    usb0/4                 unknown    disconnected unconfigured ok
ProcedureHow to Reset a USB Device
If a USB device behaves erratically, use the cfgadm command to reset the device, which logically removes and recreates the device.
Steps
  2. Make sure the device is not in use.
  3. Reset the device.
    # cfgadm -x usb_reset -y usb0/4.7
  4. Verify that the device is connected.
    # cfgadm usb0/4.7
ProcedureHow to Change the Default Configuration of a Multi-Configuration USB Device
Keep the following in mind when working with multi-configuration USB devices:
Steps
  1. Make sure the device is not in use.
  2. Change the default USB configuration.
    For example:
    # cfgadm -x usb_config -o config=2 usb0/4
       Setting the device: /devices/pci@1f,0/usb@c,3:4
       to USB configuration 2
       Continue (yes/no)? yes
  3. Verify the device change.
    For example:
    # cfgadm -lv usb0/4
    Ap_Id  Receptacle   Occupant     Condition  Information When  Type
         Busy     Phys_Id
    usb0/4 connected    unconfigured ok         Mfg: Sun  2000
    Product: USB-B0B0 aka Robotech
    With 6 EPPS High Clk Mode   NConfigs: 7  Config: 2  : EVAL Board Setup
    unavailable
    usb-device   n        /devices/pci@1f,0/usb@c,3:4
    Config now shows 2.
