System Administration Guide: Devices and File Systems
How to Display USB Device Information (prtconf)
Use the prtconf command to display information about USB devices.
$ prtconf
        usb, instance #0
                 hub, instance #2
                     device, instance #8
                         interface (driver not attached)
                     printer (driver not attached)
                     mouse, instance #14
                     device, instance #9
                         keyboard, instance #15
                         mouse, instance #16
                     storage, instance #7
                         disk (driver not attached)
                     communications, instance #10
                         modem (driver not attached)
                         data (driver not attached)
                 storage, instance #0
                 storage, instance #1
You can use the prtconf command's -D option to display additional driver information. This information can be used to tell which ports and devices are being driven by the USBA 1.0 framework on SPARC systems, as displayed in the following example:
$ prtconf -D
SUNW,Sun-Blade-1500
1 pci, instance #0 (driver name: pcisch)
           isa, instance #0 (driver name: ebus)
2 usb, instance #0 (driver name: ohci)
           usb, instance #1 (driver name: ohci)
3 pci, instance #0 (driver name: pci_pci)
4 usb, instance #0 (driver name: usba10_ohci)
            usb, instance #1 (driver name: usba10_ohci)
            usb, instance #0 (driver name: usba10_ehci)
                storage, instance #9 (driver name: usba10_scsa2usb)
                    disk, instance #9 (driver name: usb_sd)
            firewire, instance #0 (driver name: hci1394)
In the output above, note the following configuration characteristics:
