System Administration Guide: Devices and File Systems
How to Display USB Bus Information (cfgadm)
Use the cfgadm command to display USB bus information. For example:
% cfgadm
Ap_Id                       Type         Receptacle   Occupant     Condition
usb0/4.5                    usb-hub      connected    configured   ok
usb0/4.5.1                  usb-device   connected    configured   ok
usb0/4.5.2                  usb-printer  connected    configured   ok
usb0/4.5.3                  usb-mouse    connected    configured   ok
usb0/4.5.4                  usb-device   connected    configured   ok
usb0/4.5.5                  usb-storage  connected    configured   ok
usb0/4.5.6                  usb-communi  connected    configured   ok
usb0/4.5.7                  unknown      empty        unconfigured ok
usb0/4.6                    usb-storage  connected    configured   ok
usb0/4.7                    usb-storage  connected    configured   ok
In the preceding example, usb0/4.5.1 identifies a device connected to port 1 of the second-level external hub, which is connected to port 5 of first-level external hub, which is connected to the first USB controller's root hub, port 4.
Use the following cfgadm command to display specific USB device information. For example:
% cfgadm -l -s "cols=ap_id:info"
Ap_Id       Information
 usb0/4.5.1  Mfg: Inside Out Networks Product: Edgeport/421 NConfigs: 1
Config: 0  : ...
 usb0/4.5.2  Mfg: <undef> Product: <undef>   NConfigs: 1 Config: 0 ...
 usb0/4.5.3  Mfg: Mitsumi Product: Apple USB Mouse NConfigs: 1 Config: 0 ...
 usb0/4.5.4  Mfg: NMB  Product: NMB USB KB/PS2 M NConfigs: 1 Config: 0
 usb0/4.5.5  Mfg: Hagiwara Sys-Com  Product: SmartMedia R/W  NConfigs: 1
Config: 0 : ...
 usb0/4.5.6  Mfg: 3Com Inc.  Product: U.S.Robotics 56000 Voice USB Modem
NConfigs: 2 ...
 usb0/4.5.7
 usb0/4.6    Mfg: Iomega  Product: USB Zip 250  NConfigs: 1  Config: 0
 : Default
 usb0/4.7    Mfg: Iomega  Product: USB Zip 100  NConfigs: 1  Config: 0
 : Default
For examples of using the prtconf command to display USB configuration information, see How to Display USB Device Information (prtconf).
