System Administration Guide: Devices and File Systems
SPARC: Disk Slices
The following table describes the slices on a SPARC based system.
Table 10–2 SPARC: Customary Disk Slices
Slice
File System
Usually Found on Client or Server Systems?
Comments
root (/)
Both
Holds files and directories that make up the operating system.
EFI – You cannot boot from a disk with an EFI label.
swap
Both
Provides virtual memory, or swap space.
Both
VTOC – Refers to the entire disk, by convention. The size of this slice should not be changed.
EFI – Optional slice to be defined based on your site's needs.
/export
Both
Optional slice that can be defined based on your site's needs.
Can be used on a server to hold alternative versions of operating systems that are required by client systems.
Both
Both
Can be used to hold application software added to a system. If a slice is not allocated for the /opt file system during installation, the /opt directory is put in slice 0.
/usr
Both
Holds operating system commands (also known as executables). This slice also holds documentation, system programs (init and syslogd, for example) and library routines.
/home or
/export/home
Both
VTOC – Holds files that are created by users.
EFI – Not applicable.
N/A
N/A
VTOC – Not applicable.
EFI – A reserved slice created by default. This area is similar to the VTOC's alternate cylinders. Do not modify nor delete this slice.
