System Administration Guide: Devices and File Systems
Troubleshooting Problems With EFI Disk Labels
Use the following error messages and solutions to troubleshooting problems with EFI-labeled disks.
Error Message
The capacity of this LUN is too large.
Reconfigure this LUN so that it is < 2TB.
Cause
You attempted to create a partition on a SCSI device that is larger than 2 terabytes.
Solution
Create a partition on a SCSI device that is less than 2 terabytes.
Error Message
Dec  3 09:26:48 holoship scsi: WARNING: /sbus@a,0/SUNW,socal@d,10000/
sf@1,0/ssd@w50020f23000002a4,0 (ssd1):
Dec  3 09:26:48 holoship disk has 2576941056 blocks, which is too large
for a 32-bit kernel
Cause
You attempted to boot a system running a 32-bit SPARC kernel with a disk greater than 1 terabyte.
Solution
Boot a system running a 64-bit SPARC kernel with a disk greater than 1 terabyte.
Error Message
Dec  3 09:12:17 holoship scsi: WARNING: /sbus@a,0/SUNW,socal@d,10000/
Dec  3 09:12:17 holoship corrupt label - wrong magic number
Cause
You attempted to add this disk to a system running an older Solaris release.
Solution
Add this disk to a system running the Solaris release that supports the EFI disk label.
