System Administration Guide: Devices and File Systems
Specifying format Command Names
Command names are needed as input whenever the format utility displays a menu prompt. You can abbreviate the command names, as long as what you enter is sufficient to uniquely identify the command desired.
For example, use p to enter the partition menu from the format menu. Then, enter p to display the current slice table.
format> p
PARTITION MENU:
        0      - change `0' partition
        1      - change `1' partition
        2      - change `2' partition
        3      - change `3' partition
        4      - change `4' partition
        5      - change `5' partition
        6      - change `6' partition
        7      - change `7' partition
        select - select a predefined table
        modify - modify a predefined partition table
        name   - name the current table
        print  - display the current table
        label  - write partition map and label to the disk
        quit
partition> p
