System Administration Guide: Devices and File Systems
The partition Menu
The partition menu looks similar to the following:
format> partition
PARTITION MENU:
        0      - change `0' partition
        1      - change `1' partition
        2      - change `2' partition
        3      - change `3' partition
        4      - change `4' partition
        5      - change `5' partition
        6      - change `6' partition
        7      - change `7' partition
        select - select a predefined table
        modify - modify a predefined partition table
        name   - name the current table
        print  - display the current table
        label  - write partition map and label to the disk
        quit
partition>
The following table describes the partition menu items.
Table 14–2 Descriptions for partition Menu Items
Sub-Command
Description
change `n' partition
Lets you specify the following information for the new slice:
  • Identification tag
  • Permission flags
  • Starting cylinder
  • Size
select
Lets you choose a predefined slice table.
modify
Lets you change all the slices in the slice table. This command is preferred over the individual change `x' partition commands.
name
Lets you specify a name for the current slice table.
print
Displays the current slice table.
label
Writes the slice map and the label to the current disk.
quit
Exits the partition menu.
