System Administration Guide: Devices and File Systems
Administering Disks (Task Map)
Task
Description
For Instructions
Identify the disks on a system
If you are not sure of the types of disks on a system, use the format utility to identify the disk types.
How to Identify the Disks on a System
Format the disk
Determine whether a disk is already formatted by using the format utility.
How to Determine if a Disk is Formatted
In most cases, disks are already formatted. Use the format utility if you need to format a disk.
How to Format a Disk
Display slice information
Display slice information by using the format utility.
How to Display Disk Slice Information
Label the disk
Create the disk label by using the format utility.
How to Label a Disk
Examine the disk label
Examine the disk label by using the prtvtoc command.
How to Examine a Disk Label
Recover a corrupted disk label
You can attempt to recover a disk label that was damaged due to a system or power failure.
How to Recover a Corrupted Disk Label
Create a format.dat entry
Create a format.dat entry to support a third-party disk.
How to Create a format.dat Entry
Automatically configure a SCSI disk
You can automatically configure a SCSI disk with the SCSI-2 specification for disk device mode sense pages even if the specific drive type is not listed in the /etc/format.dat file.
How to Automatically Configure a SCSI Drive
Repair a defective disk sector
Identify a defective disk sector by using the format utility.
How to Identify a Defective Sector by Using Surface Analysis
If necessary, fix a defective disk sector
Fix a defective disk sector by using the format utility.
How to Repair a Defective Sector
