A system disk contains the root (/) or /usr file systems, or both. If the disk that contains either of these file systems becomes damaged, you have two ways to recover:
You can reinstall the entire Solaris environment.
Or, you can replace the system disk and restore your file systems from a backup medium.
A secondary disk doesn't contain the root (/) and /usr file systems. A secondary disk usually contains space for user files. You can add a secondary disk to a system for more disk space, or you can replace a damaged secondary disk. If you replace a secondary disk on a system, you can restore the old disk's data on the new disk.
This procedure assumes that the system is down.
Disconnect the damaged system disk from the system.
Make sure that the disk you are adding has a different target number than the other devices on the system.
You will often find a small switch located at the back of the disk for this purpose.
Connect the replacement system disk to the system and check the physical connections.
Refer to the disk's hardware installation guide for installation details.
Follow steps a-e if you are booting from a local Solaris CD or DVD or a remote Solaris CD or DVD from the network.
If you are booting from the network, skip step a.
If you are booting from a local Solaris CD or DVD, insert the Solaris installation CD or DVD into the drive.
Insert the Solaris boot diskette into the primary diskette drive (DOS drive A).
Press any key to reboot the system if the system displays the Type any key to continue prompt. Or, use the reset button to restart the system if the system is shut down.
The Boot Solaris screen is displayed after a few minutes.
Select the CD-ROM drive or net(work) as the boot device from the Boot Solaris screen.
The Current Boot Parameters screen is displayed.
Boot the system in single-user mode.
Select the type of installation: b -s |
After a few minutes, the root prompt (#) is displayed.
After you boot the system, you can create an fdisk partition. Go to x86: How to Create a Solaris fdisk Partition.
Become superuser or assume an equivalent role.
If the disk is unsupported by the Solaris software, add the device driver for the disk by following the instructions included with the hardware.
Create the /reconfigure file that will be read when the system is booted.
# touch /reconfigure |
The /reconfigure file causes the SunOS software to check for the presence of any newly installed peripheral devices when you power on or boot your system later.
Shut down the system.
# shutdown -i0 -gn -y |
Brings the system down to run level 0, the power-down state.
Notifies logged-in users that they have n seconds before the system begins to shut down.
Specifies that the command should run without user intervention.
The Type any key to continue prompt is displayed.
Turn off the power to the system and all external peripheral devices.
Connect the disk to the system and check the physical connections.
Turn on the power to all external peripherals.
Turn on the power to the system.
The system boots and displays the login prompt.
Follow these guidelines when you set up the fdisk partition.
The disk can be divided into a maximum of four fdisk partitions. One of partitions must be a Solaris partition.
The Solaris partition must be made the active partition on the disk. The active partition is partition whose operating system will be booted by default at system startup.
Solaris fdisk partitions must begin on cylinder boundaries.
Solaris fdisk partitions must begin at cylinder 1, not cylinder 0, on the first disk because additional boot information, including the master boot record, is written in sector 0.
The Solaris fdisk partition can be the entire disk or you might want to make it smaller to allow room for a DOS partition. You can also make a new fdisk partition on a disk without disturbing existing partitions (if there is enough room to create a new one).
Solaris slices are sometimes called partitions. This book uses the term slice, but some Solaris documentation and programs might refer to a slice as a partition.
To avoid confusion, Solaris documentation tries to distinguish between fdisk partitions (which are supported only on Solaris (x86 Platform Edition)) and the divisions within the Solaris fdisk partition, which might be called slices or partitions.
# format |
For more information, see format(1M).
Type the number of the disk on which to create a Solaris fdisk partition from the list displayed on your screen.
Specify disk (enter its number): disk-number |
disk-number is the number of the disk on which you want to create a Solaris fdisk partition.
Select the fdisk menu.
format> fdisk |
The fdisk menu that is displayed depends upon whether the disk has existing fdisk partitions. Determine the next step using the following table.
Task |
Go To |
For More Information |
Create a Solaris fdisk partition to span the entire disk. |
Step 6 | |
Create a Solaris fdisk partition and preserve one or more existing non-Solaris fdisk partition. |
Step 7 | |
Create a Solaris fdisk partition and one or more additional non-Solaris fdisk partition. |
Step 7 |
Create and activate a Solaris fdisk partition that spans the entire disk by specifying y at the prompt. Then, go to step 14.
The recommended default partitioning for your disk is: a 100% “SOLARIS System” partition. To select this, please type “y”. To partition your disk differently, type “n” and the “fdisk” program will let you select other partitions. y |
Specify n at the prompt if you do not want the Solaris fdisk partition to span the entire disk.
To select this, please type "y". To partition your disk differently, type "n" and the "fdisk" program will let you select other partitions. n Total disk size is 2694 cylinders Cylinder size is 765 (512 byte) blocks Cylinders Partition Status Type Start End Length % ========= ====== ======== ===== === ====== === THERE ARE NO PARTITIONS CURRENTLY DEFINED SELECT ONE OF THE FOLLOWING: 1. Create a partition 2. Change Active (Boot from) partition 3. Delete a partition 4. Exit (Update disk configuration and exit) 5. Cancel (Exit without updating disk configuration) Enter Selection: |
Select option 1, Create a partition, to create an fdisk partition.
Total disk size is 2694 cylinders Cylinder size is 765 (512 byte) blocks Cylinders Partition Status Type Start End Length % ========= ====== ======== ===== === ====== === THERE ARE NO PARTITIONS CURRENTLY DEFINED SELECT ONE OF THE FOLLOWING: 1. Create a partition 2. Change Active (Boot from) partition 3. Delete a partition 4. Exit (Update disk configuration and exit) 5. Cancel (Exit without updating disk configuration) Enter Selection: 1 |
Create a Solaris fdisk partition by selecting 1(=Solaris).
Indicate the type of partition you want to create (1=SOLARIS, 2=UNIX, 3=PCIXOS, 4=Other, 8=DOSBIG) (5=DOS12, 6=DOS16, 7=DOSEXT, 0=Exit) ? 1 |
Identify the percentage of the disk to be reserved for the Solaris fdisk partition. Keep in mind the size of any existing fdisk partitions when you calculate this percentage.
Indicate the percentage of the disk you want this partition to use (or enter "c" to specify in cylinders). nn |
Activate the Solaris fdisk partition by typing y at the prompt.
Do you want this to become the Active partition? If so, it will be activated each time you reset your computer or when you turn it on again. Please type "y" or "n". y |
The Enter Selection: prompt is displayed after the fdisk partition is activated.
Select option 1, Create a partition, to create another fdisk partition.
See steps 9-11 for instructions on creating an fdisk partition.
Update the disk configuration and exit the fdisk menu from the selection menu.
Selection: 4 |
Relabel the disk by using the label command.
WARNING: Solaris fdisk partition changed - Please relabel the disk format> label Ready to label disk, continue? yes format> |
Quit the format menu.
format> quit |
The following example uses the format's utility's fdisk option to create a Solaris fdisk partition that spans the entire drive.
# format Searching for disks...done AVAILABLE DISK SELECTIONS: 0. c0d0 <DEFAULT cyl 2466 alt 2 hd 16 sec 63> /pci@0,0/pci-ide@7,1/ide@0/cmdk@0,0 1. c0d1 <DEFAULT cyl 522 alt 2 hd 32 sec 63> /pci@0,0/pci-ide@7,1/ide@0/cmdk@1,0 2. c1d0 <DEFAULT cyl 13102 alt 2 hd 16 sec 63> /pci@0,0/pci-ide@7,1/ide@1/cmdk@0,0 Specify disk (enter its number): 0 selecting c0d0 Controller working list found [disk formatted] format> fdisk The recommended default partitioning for your disk is: a 100% "SOLARIS System" partition. To select this, please type "y". To partition your disk differently, type "n" and the "fdisk" program will let you select other partitions. y WARNING: Solaris fdisk partition changed - Please relabel the disk format> label Ready to label disk, continue? yes format> quit |
The following example shows how to create a Solaris fdisk partition on a disk that has an existing DOS-BIG fdisk partition.
format> fdisk Total disk size is 2694 cylinders Cylinder size is 765 (512 byte) blocks Cylinders Partition Status Type Start End Length % ========= ====== ======== ===== === ====== === 1 DOS-BIG 1 538 538 20 SELECT ONE OF THE FOLLOWING: 1. Create a partition 2. Change Active (Boot from) partition 3. Delete a partition 4. Exit (Update disk configuration and exit) 5. Cancel (Exit without updating disk configuration) Enter Selection: 1 Indicate the type of partition you want to create (1=SOLARIS, 2=UNIX, 3=PCIXOS, 4=Other, 8=DOSBIG) (5=DOS12, 6=DOS16, 7=DOSEXT, 0=Exit) ?1 Indicate the percentage of the disk you want this partition to use (or enter "c" to specify in cylinders). 80 Do you want this to become the Active partition? If so, it will be activated each time you reset your computer or when you turn it on again. Please type "y" or "n". y Partition 2 is now the Active partition Total disk size is 2694 cylinders Cylinder size is 765 (512 byte) blocks Cylinders Partition Status Type Start End Length % ========= ====== ======== ===== === ====== === 1 DOS-BIG 1 538 538 20 2 Active SOLARIS 539 2693 2155 80 SELECT ONE OF THE FOLLOWING: 1. Create a partition 2. Change Active (Boot from) partition 3. Delete a partition 4. Exit (Update disk configuration and exit) 5. Cancel (Exit without updating disk configuration) Enter Selection: Selection: 4 WARNING: Solaris fdisk partition changed - Please relabel the disk format> label Ready to label disk, continue? yes format> q |
This following example shows how to create a Solaris fdisk partition and a DOSBIG fdisk partition.
format> fdisk The recommended default partitioning for your disk is: a 100% "SOLARIS System" partition. To select this, please type "y". To partition your disk differently, type "n" and the "fdisk" program will let you select other partitions. n Total disk size is 2694 cylinders Cylinder size is 765 (512 byte) blocks Cylinders Partition Status Type Start End Length % ========= ====== ======== ===== === ====== === THERE ARE NO PARTITIONS CURRENTLY DEFINED SELECT ONE OF THE FOLLOWING: 1. Create a partition 2. Change Active (Boot from) partition 3. Delete a partition 4. Exit (Update disk configuration and exit) 5. Cancel (Exit without updating disk configuration) Enter Selection: 1 Indicate the type of partition you want to create (1=SOLARIS, 2=UNIX, 3=PCIXOS, 4=Other, 8=DOSBIG) (5=DOS12, 6=DOS16, 7=DOSEXT, 0=Exit) ?8 Indicate the percentage of the disk you want this partition to use (or enter "c" to specify in cylinders). 20 Do you want this to become the Active partition? If so, it will be activated each time you reset your computer or when you turn it on again. Please type "y" or "n". n Total disk size is 2694 cylinders Cylinder size is 765 (512 byte) blocks Cylinders Partition Status Type Start End Length % ========= ====== ======== ===== === ====== === 1 DOS-BIG 1 538 538 20 SELECT ONE OF THE FOLLOWING: 1. Create a partition 2. Change Active (Boot from) partition 3. Delete a partition 4. Exit (Update disk configuration and exit) 5. Cancel (Exit without updating disk configuration)Enter Selection: 1 Indicate the type of partition you want to create (1=SOLARIS, 2=UNIX, 3=PCIXOS, 4=Other, 8=DOSBIG) (5=DOS12, 6=DOS16, 7=DOSEXT, 0=Exit) ?1 Indicate the percentage of the disk you want this partition to use (or enter "c" to specify in cylinders). 80 Do you want this to become the Active partition? If so, it will be activated each time you reset your computer or when you turn it on again. Please type "y" or "n". y Partition 2 is now the Active partition Total disk size is 2694 cylinders Cylinder size is 765 (512 byte) blocks Cylinders Partition Status Type Start End Length % ========= ====== ======== ===== === ====== === 1 DOS-BIG 1 538 538 20 2 Active SOLARIS 539 2693 2155 80 SELECT ONE OF THE FOLLOWING: 1. Create a partition 2. Change Active (Boot from) partition 3. Delete a partition 4. Exit (Update disk configuration and exit) 5. Cancel (Exit without updating disk configuration) Enter Selection: 4 format> q |
After you create a Solaris fdisk partition on the disk, you can create slices on the disk. Go to x86: How to Create Disk Slices and Label a Disk.
# format |
Type the number of the disk that you want to repartition from the list displayed on your screen.
disk-number is the number of the disk that you want to repartition.
Select the partition menu.
format> partition |
Display the current partition (slice) table.
partition> print |
Start the modification process.
partition> modify |
Set the disk to all free hog.
Choose base (enter number) [0]? 1 |
For more information about the free hog slice, see Using the Free Hog Slice.
Create a new partition table by answering yes when prompted to continue.
Do you wish to continue creating a new partition table based on above table[yes]? yes |
Identify the free hog partition (slice) and the sizes of the slices when prompted.
When adding a system disk, you must set up slices for:
root (slice 0) and swap (slice 1) and/or
/usr (slice 6)
After you identify the slices, the new partition table is displayed.
Make the displayed partition table the current partition table by answering yes when asked.
Okay to make this the current partition table[yes]? yes |
If you don't want the current partition table and you want to change it, answer no and go to Step 6.
Name the partition table.
Enter table name (remember quotes): "partition-name" |
partition-name is the name for the new partition table.
Label the disk with the new partition table after you have finished allocating slices on the new disk.
Ready to label disk, continue? yes |
Quit the partition menu.
partition> quit |
Verify the new disk label.
format> verify |
Exit the format menu.
format> quit |
After you create disk slices and label the disk, you can create file systems on the disk. Go to x86: How to Create File Systems.
Create a file system for each slice.
# newfs /dev/rdsk/cwtxdysz |
/dev/rdsk/cwtxdysz is the raw device for the file system to be created.
For more information about the newfs command, see Chapter 16, Creating UFS, TMPFS, and LOFS File Systems (Tasks) or newfs(1M).
Verify the new file system by mounting.
# mount /dev/dsk/cwtxdysz /mnt # ls /mnt lost+found |
System Disk – You need to restore the root (/) and /usr file systems on the disk. Go to Chapter 25, Restoring Files and File Systems (Tasks).
After the root (/) and /usr file systems are restored, install the boot block. Go to x86: How to Install a Boot Block on a System Disk.
Secondary Disk – You might need to restore file systems on the new disk. Go to Chapter 25, Restoring Files and File Systems (Tasks). If you are not restoring file systems on the new disk, you are finished adding a secondary disk.
For information on making the file systems available to users, see Chapter 17, Mounting and Unmounting File Systems (Tasks).
Install the boot block on the system disk.
# installboot /usr/platform/`uname -i`/lib/fs/ufs/pboot /usr/platform/ `uname -i` /lib/fs/ufs/bootblk /dev/rdsk/cwtxdys2 |
Is the partition boot file.
Is the boot block code.
Is the raw device name that represents the whole disk.
Verify that the boot blocks are installed by rebooting the system to run level 3.
# init 6 |
# installboot /usr/platform/i86pc/lib/fs/ufs/pboot /usr/platform/i86pc/lib/fs/ufs/bootblk /dev/rdsk/c0t6d0s2 |
