Become superuser or assume an equivalent role.
# format |
For more information, see format(1M).
Type the number of the disk on which to create a Solaris fdisk partition from the list displayed on your screen.
Specify disk (enter its number): disk-number |
disk-number is the number of the disk on which you want to create a Solaris fdisk partition.
Select the fdisk menu.
format> fdisk |
The fdisk menu that is displayed depends upon whether the disk has existing fdisk partitions. Determine the next step using the following table.
Task |
Go To |
For More Information |
Create a Solaris fdisk partition to span the entire disk. |
Step 6 | |
Create a Solaris fdisk partition and preserve one or more existing non-Solaris fdisk partition. |
Step 7 | |
Create a Solaris fdisk partition and one or more additional non-Solaris fdisk partition. |
Step 7 |
Create and activate a Solaris fdisk partition that spans the entire disk by specifying y at the prompt. Then, go to step 14.
The recommended default partitioning for your disk is: a 100% “SOLARIS System” partition. To select this, please type “y”. To partition your disk differently, type “n” and the “fdisk” program will let you select other partitions. y |
Specify n at the prompt if you do not want the Solaris fdisk partition to span the entire disk.
To select this, please type "y". To partition your disk differently, type "n" and the "fdisk" program will let you select other partitions. n Total disk size is 2694 cylinders Cylinder size is 765 (512 byte) blocks Cylinders Partition Status Type Start End Length % ========= ====== ======== ===== === ====== === THERE ARE NO PARTITIONS CURRENTLY DEFINED SELECT ONE OF THE FOLLOWING: 1. Create a partition 2. Change Active (Boot from) partition 3. Delete a partition 4. Exit (Update disk configuration and exit) 5. Cancel (Exit without updating disk configuration) Enter Selection: |
Select option 1, Create a partition, to create an fdisk partition.
Total disk size is 2694 cylinders Cylinder size is 765 (512 byte) blocks Cylinders Partition Status Type Start End Length % ========= ====== ======== ===== === ====== === THERE ARE NO PARTITIONS CURRENTLY DEFINED SELECT ONE OF THE FOLLOWING: 1. Create a partition 2. Change Active (Boot from) partition 3. Delete a partition 4. Exit (Update disk configuration and exit) 5. Cancel (Exit without updating disk configuration) Enter Selection: 1 |
Create a Solaris fdisk partition by selecting 1(=Solaris).
Indicate the type of partition you want to create (1=SOLARIS, 2=UNIX, 3=PCIXOS, 4=Other, 8=DOSBIG) (5=DOS12, 6=DOS16, 7=DOSEXT, 0=Exit) ? 1 |
Identify the percentage of the disk to be reserved for the Solaris fdisk partition. Keep in mind the size of any existing fdisk partitions when you calculate this percentage.
Indicate the percentage of the disk you want this partition to use (or enter "c" to specify in cylinders). nn |
Activate the Solaris fdisk partition by typing y at the prompt.
Do you want this to become the Active partition? If so, it will be activated each time you reset your computer or when you turn it on again. Please type "y" or "n". y |
The Enter Selection: prompt is displayed after the fdisk partition is activated.
Select option 1, Create a partition, to create another fdisk partition.
See steps 9-11 for instructions on creating an fdisk partition.
Update the disk configuration and exit the fdisk menu from the selection menu.
Selection: 4 |
Relabel the disk by using the label command.
WARNING: Solaris fdisk partition changed - Please relabel the disk format> label Ready to label disk, continue? yes format> |
Quit the format menu.
format> quit |
The following example uses the format's utility's fdisk option to create a Solaris fdisk partition that spans the entire drive.
# format Searching for disks...done AVAILABLE DISK SELECTIONS: 0. c0d0 <DEFAULT cyl 2466 alt 2 hd 16 sec 63> /pci@0,0/pci-ide@7,1/ide@0/cmdk@0,0 1. c0d1 <DEFAULT cyl 522 alt 2 hd 32 sec 63> /pci@0,0/pci-ide@7,1/ide@0/cmdk@1,0 2. c1d0 <DEFAULT cyl 13102 alt 2 hd 16 sec 63> /pci@0,0/pci-ide@7,1/ide@1/cmdk@0,0 Specify disk (enter its number): 0 selecting c0d0 Controller working list found [disk formatted] format> fdisk The recommended default partitioning for your disk is: a 100% "SOLARIS System" partition. To select this, please type "y". To partition your disk differently, type "n" and the "fdisk" program will let you select other partitions. y WARNING: Solaris fdisk partition changed - Please relabel the disk format> label Ready to label disk, continue? yes format> quit |
The following example shows how to create a Solaris fdisk partition on a disk that has an existing DOS-BIG fdisk partition.
format> fdisk Total disk size is 2694 cylinders Cylinder size is 765 (512 byte) blocks Cylinders Partition Status Type Start End Length % ========= ====== ======== ===== === ====== === 1 DOS-BIG 1 538 538 20 SELECT ONE OF THE FOLLOWING: 1. Create a partition 2. Change Active (Boot from) partition 3. Delete a partition 4. Exit (Update disk configuration and exit) 5. Cancel (Exit without updating disk configuration) Enter Selection: 1 Indicate the type of partition you want to create (1=SOLARIS, 2=UNIX, 3=PCIXOS, 4=Other, 8=DOSBIG) (5=DOS12, 6=DOS16, 7=DOSEXT, 0=Exit) ?1 Indicate the percentage of the disk you want this partition to use (or enter "c" to specify in cylinders). 80 Do you want this to become the Active partition? If so, it will be activated each time you reset your computer or when you turn it on again. Please type "y" or "n". y Partition 2 is now the Active partition Total disk size is 2694 cylinders Cylinder size is 765 (512 byte) blocks Cylinders Partition Status Type Start End Length % ========= ====== ======== ===== === ====== === 1 DOS-BIG 1 538 538 20 2 Active SOLARIS 539 2693 2155 80 SELECT ONE OF THE FOLLOWING: 1. Create a partition 2. Change Active (Boot from) partition 3. Delete a partition 4. Exit (Update disk configuration and exit) 5. Cancel (Exit without updating disk configuration) Enter Selection: Selection: 4 WARNING: Solaris fdisk partition changed - Please relabel the disk format> label Ready to label disk, continue? yes format> q |
This following example shows how to create a Solaris fdisk partition and a DOSBIG fdisk partition.
format> fdisk The recommended default partitioning for your disk is: a 100% "SOLARIS System" partition. To select this, please type "y". To partition your disk differently, type "n" and the "fdisk" program will let you select other partitions. n Total disk size is 2694 cylinders Cylinder size is 765 (512 byte) blocks Cylinders Partition Status Type Start End Length % ========= ====== ======== ===== === ====== === THERE ARE NO PARTITIONS CURRENTLY DEFINED SELECT ONE OF THE FOLLOWING: 1. Create a partition 2. Change Active (Boot from) partition 3. Delete a partition 4. Exit (Update disk configuration and exit) 5. Cancel (Exit without updating disk configuration) Enter Selection: 1 Indicate the type of partition you want to create (1=SOLARIS, 2=UNIX, 3=PCIXOS, 4=Other, 8=DOSBIG) (5=DOS12, 6=DOS16, 7=DOSEXT, 0=Exit) ?8 Indicate the percentage of the disk you want this partition to use (or enter "c" to specify in cylinders). 20 Do you want this to become the Active partition? If so, it will be activated each time you reset your computer or when you turn it on again. Please type "y" or "n". n Total disk size is 2694 cylinders Cylinder size is 765 (512 byte) blocks Cylinders Partition Status Type Start End Length % ========= ====== ======== ===== === ====== === 1 DOS-BIG 1 538 538 20 SELECT ONE OF THE FOLLOWING: 1. Create a partition 2. Change Active (Boot from) partition 3. Delete a partition 4. Exit (Update disk configuration and exit) 5. Cancel (Exit without updating disk configuration)Enter Selection: 1 Indicate the type of partition you want to create (1=SOLARIS, 2=UNIX, 3=PCIXOS, 4=Other, 8=DOSBIG) (5=DOS12, 6=DOS16, 7=DOSEXT, 0=Exit) ?1 Indicate the percentage of the disk you want this partition to use (or enter "c" to specify in cylinders). 80 Do you want this to become the Active partition? If so, it will be activated each time you reset your computer or when you turn it on again. Please type "y" or "n". y Partition 2 is now the Active partition Total disk size is 2694 cylinders Cylinder size is 765 (512 byte) blocks Cylinders Partition Status Type Start End Length % ========= ====== ======== ===== === ====== === 1 DOS-BIG 1 538 538 20 2 Active SOLARIS 539 2693 2155 80 SELECT ONE OF THE FOLLOWING: 1. Create a partition 2. Change Active (Boot from) partition 3. Delete a partition 4. Exit (Update disk configuration and exit) 5. Cancel (Exit without updating disk configuration) Enter Selection: 4 format> q |
After you create a Solaris fdisk partition on the disk, you can create slices on the disk. Go to x86: How to Create Disk Slices and Label a Disk.
