Unpack files or packing lists from the cache by using the -u or -U option of the cachefspack command.
$ cachefspack -u filename | -U cache-directory |
Specifies that you want the file or files unpacked. You must specify a filename with this option.
Specifies the name of the file or packing list that you want unpacked in the cache.
Specifies that you want to unpack all files in the cache.
For more information about the cachefspack command, see the man page.
The following example shows the file /data/abc/bin/big being unpacked from the cache.
$ cachefspack -u /data/abc/bin/big |
The following example shows several files being unpacked from the cache.
$ cd /data/abc/bin/big $ cachefspack -u big small medium |
The following example shows how to unpack a packing list, which is a file that contains the path to a directory of files, as follows:
$ cachefspack -uf list.pkg |
The following example uses the -U option to specify that all files in a cache directory being unpacked.
$ cachefspack -U /local/mycache |
You cannot unpack a cache that does not have at least one file system mounted. With the -U option, if you specify a cache that does not contain mounted file systems, you see output similar to the following:
$ cachefspack -U /local/mycache cachefspack: Could not unpack cache /local/mycache, no mounted filesystems in the cache. |
