System Administration Guide: Devices and File Systems
Packing a CacheFS File System
For general use, the CacheFS software operates automatically after it is set up, without requiring any action from the user. Files are cached on a most recently used basis. With the packing feature, you can take a more active role in managing your cache by ensuring that certain files or directories are always updated in the cache.
You can specify files and directories to be loaded in the cache with the cachefspack command. This command ensures that current copies of these files are available in the cache.
The packing list contains the names of specific files and directories. The packing list can also contain other packing lists. This feature saves you having to specify individual files and directories when you have many items to pack in your cache.
You can print out a brief help summary of all the cachefspack options by using the -h option as follows:
$ cachefspack -h
Must select 1 and only 1 of the following 5 options
-d Display selected filenames
-i Display selected filenames packing status
-p Pack selected filenames
-u Unpack selected filenames
-U Unpack all files in directory 'dir'
-f Specify input file containing rules
-h Print usage information
-r Interpret strings in LIST rules as regular expressions
-s Strip './' from the beginning of a pattern name
-v Verbose option
files - a list of filenames to be packed/unpacked
How to Pack Files in the Cache
Pack files in the cache by using the cachefspack command.
$ cachefspack -p filename
-p
Specifies that you want the file or files to be packed. This option is also the default.
filename
Specifies the name of the files or directory you want packed in the cache. When you specify a directory, all of its subdirectories are also packed. For more information, see cachefspack(1M).
Examples—Packing Files in the Cache
The following example shows the projects file being packed in the cache.
$ cachefspack -p projects
The following example shows three files being packed in the cache.
$ cachefspack -p projects updates master_plan
The following example shows a directory being packed in the cache.
$ cachefspack -p /data/abc/bin
How to Display Packed Files Information
Display packed files information by using the cachefspack -i command.
$ cachefspack -i[v] filename
-i
Specifies that you want to view information about your packed files.
-v
Is the verbose option.
cached-filename-or-directory
Specifies the name of the file or directory for which to display information.
Example 18–8 Displaying Packed Files Information
The following example shows that the doc_file file is successfully packed.
$ cachefspack -i doc_file
cachefspack: file doc_file marked packed YES, packed YES
In the following example, the /data/abc directory contains the bin subdirectory. The bin subdirectory has three files: big, medium, and small. Although the big and small files are specified to be packed, they are not. The medium file is successfully packed.
$ cd /data/abc
$ cachefspack -i bin
cachefspack: file /bin/big marked packed YES, packed NO
cachefspack: file /bin/medium marked packed YES,
packed YES
cachefspack: file /bin/small marked packed YES,
packed NO
If you use the -iv options together, you get additional information as to whether the file or directory specified has been flushed from the cache. For example:
$ cd /data/bin
FSCACHEPACK-4$ cachefspack -iv bin
cachefspack: file /bin/big marked packed YES, packed NO,
nocache YES
packed YES, nocache NO
packed NO
nocache NO
The last line of the preceding example shows that the directory contents have not been flushed from the cache.
Using Packing Lists
One feature of the cachefspack command is the ability to create packing lists.
A packing list contains files or directories to be packed in the cache. If a directory is in the packing list, all of its subdirectories and files will also be packed.
This feature saves the time of having to specify each individual file that you want packed in the cache.
How to Create a Packing List
To create a packing list, open a file by using vi or the editor of your choice. The packing list file format uses the same format as the filesync command. For more information, see filesync(1).
Two packing list features are the following:
For more information on using these features, see cachefspack(1M).
Example 18–9 Creating a Packing List
The following example shows the contents of a packing list file.
BASE /home/ignatz
LIST plans
LIST docs
IGNORE *.ps
How to Pack Files in the Cache With a Packing List
Pack files in the packing list by using the cachefspack -f command, as follows:
$ cachefspack -f packing-list
-f
Specifies that you want to use a packing list.
packing-list
Specifies the name of the packing list.
Example 18–10 Packing Files in the Cache With a Packing List
This example uses the list.pkg file as the packing list for the cachefspack command.
$ cachefspack -f list.pkg
Unpacking Files or Packing Lists From the Cache
You might need to remove, or unpack, a file from the cache. Perhaps you have some files or directories that have a higher priority than others, so you need to unpack the less critical files. For example, you finished up a project and have archived the files that are associated with that project. You are now working on a new project, and therefore, a new set of files.
How to Unpack Files or Packing Lists From the Cache
Unpack files or packing lists from the cache by using the -u or -U option of the cachefspack command.
$ cachefspack -u filename | -U cache-directory
-u
Specifies that you want the file or files unpacked. You must specify a filename with this option.
filename
Specifies the name of the file or packing list that you want unpacked in the cache.
-U
Specifies that you want to unpack all files in the cache.
For more information about the cachefspack command, see the man page.
Example 18–11 Unpacking Files or Packing Lists From the Cache
The following example shows the file /data/abc/bin/big being unpacked from the cache.
$ cachefspack -u /data/abc/bin/big
The following example shows several files being unpacked from the cache.
$ cd /data/abc/bin/big
$ cachefspack -u big small medium
The following example shows how to unpack a packing list, which is a file that contains the path to a directory of files, as follows:
$ cachefspack -uf list.pkg
The following example uses the -U option to specify that all files in a cache directory being unpacked.
$ cachefspack -U /local/mycache
You cannot unpack a cache that does not have at least one file system mounted. With the -U option, if you specify a cache that does not contain mounted file systems, you see output similar to the following:
cachefspack: Could not unpack cache /local/mycache, no mounted
filesystems in the cache.
Troubleshooting cachefspack Errors
You might see the following error messages when you use the cachefspack command.
cachefspack: pathname - can't open directory: permission denied
Cause
You might not have the correct permissions to access the file or directory.
Action
Set the correct permissions.
cachefspack: pathname - can't open directory: no such file or
directory
Cause
You might not have the correct file or directory.
Action
Check for a possible typo.
cachefspack: pathname - can't open directory: stale NFS file handle
Cause
The file or directory might have been moved or deleted from the server at the time you attempted to access it.
Action
Verify that the file or directory on the server is still accessible.
cachefspack: pathname - can't open directory: interrupted system
call
Cause
You might have inadvertently pressed Control-C while issuing the command.
Action
Reissue the command.
cachefspack: pathname - can't open directory: I/O error
Cause
You might have a hardware problem.
Action
Check your hardware connections.
cachefspack: error opening dir
Cause
You might not have the correct file or directory. The path identified after the BASE command in the file format could be a file and not a directory. The path specified must be a directory.
Action
Check for a possible typo. Check the path identified after the BASE command in your file format. Make sure the path identifies a directory, not a file.
cachefspack: unable to get shared objects
Cause
The executable might be corrupt or in a format that is not recognizable.
Action
Replace the executable.
cachefspack: filename - can't pack file: permission denied
Cause
Action
cachefspack: filename - can't pack file: no such file or directory
Cause
Action
cachefspack: filename- can't pack file: stale NFS file handle
Cause
Action
cachefspack: filename- can't pack file: interrupted system call
Cause
Action
cachefspack: filename- can't pack file: I/O error
Cause
Action
cachefspack: filename- can't pack file: no space left on device.
Cause
The cache is out of disk space.
Action
You need to increase the size of the cache by increasing disk space.
cachefspack: filename - can't unpack file: permission denied
Cause
Action
cachefspack: filename - can't unpack file: no such file or directory
Cause
Action
cachefspack: filename- can't unpack file: stale NFS file handle
Cause
Action
cachefspack: filename - can't unpack file: interrupted system call
Cause
You might have pressed Control-C inadvertently while issuing the command.
Action
cachefspack: filename- can't unpack file I/O error
Cause
Action
cachefspack: only one `d', `i', `p', or `u' option allowed
Cause
You entered more than one of these options in a command session.
Action
Select one option for the command session.
cachefspack: can't find environment variable.
Cause
You forgot to set a corresponding environment variable to match the $ in your configuration file.
Action
Define the environment variable in the proper location.
cachefspack: skipping LIST command - no active base
Cause
A LIST command is present in your configuration file that has no corresponding BASE command.
Action
Define the BASE command.
