Pack files in the cache by using the cachefspack command.
$ cachefspack -p filename |
Specifies that you want the file or files to be packed. This option is also the default.
Specifies the name of the files or directory you want packed in the cache. When you specify a directory, all of its subdirectories are also packed. For more information, see cachefspack(1M).
The following example shows the projects file being packed in the cache.
$ cachefspack -p projects |
The following example shows three files being packed in the cache.
$ cachefspack -p projects updates master_plan |
The following example shows a directory being packed in the cache.
$ cachefspack -p /data/abc/bin |
