System Administration Guide: Devices and File Systems
The Platform-Dependent Directories
The following table describes the platform-dependent objects in the /platform and /usr/platform directories.
Table 21–3 The /platform and /usr/platform Directories
Directory
Description
/platform
Contains a series of directories, one directory per supported platform that needs to reside in the root (/) file system.
/platform/*/kernel
Contains platform-dependent kernel components, including the file unix, the core kernel that is platform–dependent. For more information, see kernel(1M).
/usr/platform
Contains platform-dependent objects that do not need to reside in the root (/) file system.
/usr/platform/*/lib
Contains platform-dependent objects similar to those objects found in the /usr/lib directory.
/usr/platform/*/sbin
Contains platform-dependent objects similar to those objects found in the /usr/sbin directory.
