You can configure your system to share its media drives to make any media in those drives available to other systems. (This does not apply to musical CDs.) Once your media drives are shared, other systems can access the media they contain simply by mounting them, as described in How to Access Removable Media on Remote Systems.
Become superuser.
Find out whether the NFS daemon (nfsd) is running.
# ps -ef | grep nfsd root 14533 1 17 10:46:55 ? 0:00 /usr/lib/nfs/nfsd -a 16 root 14656 289 7 14:06:02 pts/3 0:00 grep nfsd |
If the daemon is running, a line for /usr/lib/nfs/nfsd will appear, as shown above. If the daemon is not running, only the grep nfsd line will appear.
Identify the nfsd status and select one of the following:
Create a dummy directory for nfsd to share.
# mkdir / dummy-dir |
The dummy-dir mount point can be any directory name. For example, dummy. This directory will not contain any files. Its only purpose is to “wake up” the NFS daemon so that it notices your shared media drive.
Add the following entry into the /etc/dfs/dfstab file.
share -F nfs -o ro [-d comment] /dummy-dir |
When you start the NFS daemon, it will see this entry, “wake up,” and notice the shared media drive. Note that the comment (preceded by -d) is optional.
# /etc/init.d/nfs.server start |
Verify that the NFS daemon is indeed running.
# ps -ef | grep nfsd root 14533 1 17 10:46:55 ? 0:00 /usr/lib/nfs/nfsd -a 16 root 14656 289 7 14:06:02 pts/3 0:00 /grep nfsd |
Eject any media currently in the drive.
# eject media |
Assign root write permissions to the /etc/rmmount.conf file.
# chmod 644 /etc/rmmount.conf |
Add the following lines to the /etc/rmmount.conf file.
# File System Sharing share media* |
These lines share any media loaded into your system's CD-ROM drive. You can, however, limit sharing to a particular CD or series of CDs, as described in share(1M).
Remove write permissions from the /etc/rmmount.conf file.
# chmod 444 /etc/rmmount.conf |
This step returns the file to its default permissions.
Load the media.
The media you now load, and all subsequent media, will be available to other systems. Remember to wait until the light on the drive stops blinking before you verify this task.
To access the media, the remote user must mount it by name, according to the instructions in How to Access Removable Media on Remote Systems.
Verify that the media is indeed available to other systems by using the share command.
If the media is available, its share configuration will be displayed. (The shared dummy directory will also be displayed.)
# share - /dummy ro "dummy dir to wake up NFS daemon" - /cdrom/sol_9_1202_sparc/s5 ro "" - /cdrom/sol_9_1202_sparc/s4 ro "" - /cdrom/sol_9_1202_sparc/s3 ro "" - /cdrom/sol_9_1202_sparc/s2 ro "" - /cdrom/sol_9_1202_sparc/s1 ro "" - /cdrom/sol_9_1202_sparc/s0 ro "" |
The following example shows how to make any local CD available to other systems on the network.
# ps -ef | grep nfsd root 10127 9986 0 08:25:01 pts/2 0:00 grep nfsd root 10118 1 0 08:24:39 ? 0:00 /usr/lib/nfs/nfsd -a # mkdir /dummy # vi /etc/dfs/dfstab (Add the following line:) share -F nfs -o ro /dummy # eject cdrom0 # chmod 644 /etc/rmmount.conf # vi /etc/rmmount.conf (Add the following line to the File System Sharing section:) share cdrom* # chmod 444 /etc/rmmount.conf (Load a CD.) # share - /dummy ro "" - /cdrom/sol_9_1202_sparc/s5 ro "" - /cdrom/sol_9_1202_sparc/s4 ro "" - /cdrom/sol_9_1202_sparc/s3 ro "" - /cdrom/sol_9_1202_sparc/s2 ro "" - /cdrom/sol_9_1202_sparc/s1 ro "" - /cdrom/sol_9_1202_sparc/s0 ro "" |
The following example shows how to make any local diskette available to other systems on the network.
# ps -ef | grep nfsd root 10127 9986 0 08:25:01 pts/2 0:00 grep nfsd root 10118 1 0 08:24:39 ? 0:00 /usr/lib/nfs/nfsd -a # mkdir /dummy # vi /etc/dfs/dfstab (Add the following line:) share -F nfs -o ro /dummy # eject floppy0 # chmod 644 /etc/rmmount.conf # vi /etc/rmmount.conf (Add the following line to the File System Sharing section.) share floppy* # chmod 444 /etc/rmmount.conf (Load a diskette.) # volcheck -v media was found # share - /dummy ro "" - /floppy/myfiles rw "" |
The following example shows how to make any local PCMCIA memory card available to other systems on the network.
# ps -ef | grep nfsd root 10127 9986 0 08:25:01 pts/2 0:00 grep nfsd root 10118 1 0 08:24:39 ? 0:00 /usr/lib/nfs/nfsd -a # mkdir /dummy # vi /etc/dfs/dfstab (Add the following line:) share -F nfs -o ro /dummy # eject pcmem0 # chmod 644 /etc/rmmount.conf # vi /etc/rmmount.conf (Add the following line to the File System Sharing section:) share floppy* # chmod 444 /etc/rmmount.conf (Load a PCMCIA memory card.) # volcheck -v media was found # share - /dummy ro "" - /pcmem/myfiles rw "" |
