System Administration Guide: Devices and File Systems
Writing Data and Audio CDs
The process of writing to a CD cannot be interrupted and needs a constant stream of data. Consider using the cdrw -S option to simulate writing to the media to verify if the system can provide data at a rate good enough for writing to the CD.
Write errors can be caused by one of the following:
If any of these problems occur, you can lower the writing speed of the device with the cdrw -p option.
For example, simulate writing at 4x speed.
$ cdrw -iS -p 4 image.iso
You can also use the cdrw -C option to use the stated media capacity for copying an 80–minute CD. Otherwise, the cdrw command uses a default value of 74 minutes for copying an audio CD.
For more information, see cdrw(1).
Restricting User Access to Removable Media with RBAC
By default, all users can access removable media starting in the Solaris 9 release. However, you can restrict user access to removable media by setting up a role through role based access control (RBAC). Access to removable media is restricted by assigning the role to a limited set of users.
For a discussion of using roles, see Chapter 5, Role-Based Access Control (Overview), in System Administration Guide: Security Services.
ProcedureHow to Restrict User Access to Removable Media with RBAC
Steps
  1. Become superuser or assume an equivalent role.
  2. Start the Solaris Management Console.
    $ /usr/sadm/bin/smc &
    For more information on starting the console, see Starting the Solaris Management Console in System Administration Guide: Basic Administration.
  3. Set up a role that includes the Device Management rights.
    For more information, see Chapter 6, Role-Based Access Control (Tasks), in System Administration Guide: Security Services.
  4. Add users who need to use the cdrw command to the newly created role.
  5. Comment the following line in the /etc/security/policy.conf file.
    AUTHS_GRANTED=solaris.device.cdrw
    If you do not do this step, all users still have access to the cdrw command, not just the members of the device management role.
    After this file is modified, the device management role members are the only users who can use the cdrw command. Everyone else is denied access with the following message:
    Authorization failed, Cannot access disks.
How to Identify a CD Writer
Use the cdrw -l command to identify the CD writers on the system.
$ cdrw -l
Looking for CD devices...
    Node              |    Connected Device            |  Device type
 cdrom0               | YAMAHA   CRW8424S         1.0d | CD Reader/Writer
If you want to use a specific CD writer, use the -d option. For example:
$ cdrw -a filename.wav -d cdrom2
Use the cdrw -M command to to identify whether the media is blank or whether there is an existing table of contents.
$ cdrw -M
Device : YAMAHA   CRW8424S
Firmware : Rev. 1.0d (06/10/99)
Media is blank
ProcedureHow to Check the CD Media
The cdrw command works with or without vold running. However, you must have superuser or role access to stop and start the vold daemon.
Steps
  1. Insert a CD into the CD-RW device.
    The CD can be any CD that the device can read.
  2. Check that the CD-RW drive is connected properly by listing the device.
    $ cdrw -l
        Node                   Connected Device                Device type
     cdrom1               | YAMAHA   CRW8424S         1.0d | CD Reader/Writer
  3. (Optional) If you do not see the drive in the list, you might have to do a reconfiguration boot so that the system recognizes the device.
    # touch /reconfigure
    # init 6
    Or, use the following commands to add the CD-RW device without rebooting the system.
    # drvconfig
    # disks
    Then restart vold.
    # /etc/init.d/vold stop
    # /etc/init.d/vold start
Creating a Data CD
Prepare the data first by using the mkisofs command to convert the file and file information into the High Sierra format used on CDs.
ProcedureHow to Create an ISO 9660 File System for a Data CD
Steps
  1. Insert a blank CD into the CD-RW device.
  2. Create the ISO 9660 file system on the new CD.
    $ mkisofs -r /pathname > cd-file-system
    -r
    Creates Rock Ridge information and resets file ownerships to zero.
    /pathname
    Identifies the pathname used to create the ISO 9660 file system.
    > cd-file-system
    Identifies the name of the file system to be put on the CD.
  3. Copy the CD file system onto the CD.
    $ cdrw -i cd-file-system
    -i cd-file-system
    Specifies the image file for creating a data CD.
Example 4–1 Creating an ISO 9660 File System for a Data CD
The following example shows how to create a ISO 9660 file system for a data CD.
$ mkisofs -r /home/dubs/ufs_dir > ufs_cd
Total extents actually written = 56
Total translation table size: 0
Total rockridge attributes bytes: 329
Total directory bytes: 0
Path table size(bytes): 10
Max brk space used 8000
56 extents written (0 Mb)
Then copy the CD file system onto the CD. For example:
$ cdrw -i ufs_cd
Initializing device...done.
Writing track 1...done.
Finalizing (Can take several minutes)...done.
ProcedureHow to Create a Multi-Session Data CD
This procedure describes how to put more than one session on the CD. This procedure includes an example of copying the infoA and infoB directories onto the CD.
Steps
  1. Create the file system for the first CD session.
    $ mkisofs -o infoA -r -V my_infoA /data/infoA
    Total rockridge attributes bytes: 24507
    Total directory bytes: 34816
    Path table size(bytes): 98
    Max brk space used 2e000
    8929 extents written (17 Mb)
    -o infoA
    Identifies the name of the ISO file system.
    -r
    -V my_infoA
    Identifies a volume label to be used as the mount point by vold.
    /data/infoA
    Identifies the ISO image directory to create.
  2. Copy the ISO file system for the first session onto the CD.
    $ cdrw -iO infoA
    done.
    -i infoA
    Identifies the name of the image file to write to the CD.
    -O
    Keeps the CD open for writing.
  3. Re-insert the CD after it is ejected.
  4. Identify the pathname of the CD media to include in the next write session.
    $ eject -n
    cdrom0 -> /vol/dev/rdsk/c2t4d0/my_infoA
    Note the /vol/dev/... pathname.
  5. Identify the next writeable address on the CD to write the next session.
    % cdrw -M /cdrom
    Track No. |Type    |Start address
     1        |Audio   |0
     2        |Audio   |33057
     3        |Data    |60887
     4        |Data    |68087
     5        |Data    |75287
    Leadout   |Data    |84218
    Last session start address: 75287
    Next writable address: 91118
    Note the address in the Next writable address: output so you can provide this when you write the next session.
  6. Create the next ISO file system for the next CD session and write it onto the CD.
    $ mkisofs -o infoB -r -C 0,91118 -M /vol/dev/rdsk/c2t4d0/my_infoA
    /data/infoB
    Total rockridge attributes bytes: 16602
    Total directory bytes: 22528
    Path table size(bytes): 86
    Max brk space used 20000
    97196 extents written (189 Mb)
    -o infoB
    -r
    -C 0,91118
    Identifies the starting address of the first session and the next writable address.
    Specifies the path of the existing ISO image to be merged.
    /data/infoB
Creating an Audio CD
You can use the cdrw command to create audio CDs from individual audio tracks or from .au and .wav files.
The supported audio formats are:
Format
Description
sun
Sun .au files with data in Red Book CDDA format
wav
RIFF (.wav) files with data in Red Book CDDA format
cda
.cda files with raw CD audio data, which is 16–bit PCM stereo at 44.1 kHz sample rate in little-endian byte order)
aur
.aur files with raw CD data in big-endian byte order
If no audio format is specified, the cdrw command tries to determine the audio file format based on the file extension. The case of the characters in the extension is ignored.
ProcedureHow to Create an Audio CD
This procedure describes how to copy audio files onto a CD.
Steps
  2. Change to the directory that contains the audio files.
    $ cd /myaudiodir
  3. Copy the audio files onto the CD.
    $ cdrw -a track1.wav track2.wav track3.wav
    The -a option creates an audio CD.
Example 4–2 Creating an Audio CD
The following example shows how to create an audio CD.
$ cdrw -a bark.wav chirp.au meow.wav
done.
Writing track 2...done.
Writing track 3...done.
done.
The following example shows how to create a multisession audio CD. The CD is ejected after the first session is written. Re-insert the CD before the next writing session.
$ cdrw -aO groucho.wav chico.au harpo.wav
done.
done.
<Re-insert CD>
$ cdrw -a zeppo.au
done.
ProcedureHow to Extract an Audio Track on a CD
Use the following procedure to extract an audio track from a CD and copy it to a new CD.
If you don't use the cdrw -T option to specify the audio file type, cdrw uses the filename extension to determine the audio file type. For example, the cdrw command detects that this file is a .wav file.
$ cdrw -x 1 testme.wav
Steps
  1. Insert a audio CD into the CD-RW device.
  2. Extract an audio track.
    $ cdrw -x -T  audio-type 1 audio-file
    -x
    Extracts audio data from an audio CD.
    T audio-type
    Identifies the type of audio file to be extracted. Supported audio types are sun, wav, cda, or aur.
  3. Copy the track to a new CD.
    $ cdrw -a audio-file
Example 4–3 Extracting and Creating Audio CDs
The following example shows how to extract the first track from an audio CD and names the file song1.wav.
$ cdrw -x -T wav 1 song1.wav
Extracting audio from track 1...done.
This example describes how to copy a track to an audio CD.
$ cdrw -a song1.wav
ProcedureHow to Copy a CD
This procedure describes how to extract all the tracks from an audio CD into a directory and then copy all them onto a blank CD.
Note –
By default, the cdrw command copies the CD into the /tmp directory. The copying might require up to 700 Mbytes of free space. If there is insufficient space in the /tmp directory for copying the CD, use the -m option to specify an alternate directory.
Steps
  1. Insert an audio CD into a CD-RW device.
  2. Extract the tracks from the audio CD.
    $ mkdir music_dir
    $ cdrw -c -m music_dir
    An Extracting audio ... message is display for each track.
    The CD is ejected when all the tracks are extracted.
  3. Insert a blank CD and press Return.
    After the tracks are extracted, the audio CD is ejected, and you are prompted to insert a blank CD.
Example 4–4 Copying a CD
This example describes how to copy one CD to another CD. You must have two CD-RW devices to do this task.
$ cdrw -c -s cdrom0 -d cdrom1
ProcedureHow to Erase CD-RW Media
You have to erase existing CD-RW data before the CD can be rewritten.
Step
    Erase the entire media or just the last session on the CD by selecting one of the following:
    1. Erase the last session only.
      $ cdrw -d cdrom0 -b session
      Erasing just the last session with the -b session option is faster than erasing the entire media with the -b all option. You can use the -b session option even if you used the cdrw command to create a data or audio CD in just one session.
    2. Erase the entire media.
      $ cdrw -d cdrom0 -b all
