Task |
Description |
For Instructions |
1. Load unformatted media |
Insert the media into the drive and enter the volcheck command. | |
2. Format the media |
Format removable media. | |
3. (Optional) Add a UFS file system |
Add a UFS file system to use the diskette for transferring files. | |
4. (Optional) Check the media |
Verify the integrity of the file system on the media. | |
5. (Optional) Repair bad blocks on the media |
Repair any bad blocks on the media, if necessary. | |
6. (Optional) Apply Read or Write and Password Protection |
Apply read or write protection or password protection on the media, if necessary. |
How to Enable or Disable Write Protection on Removable Media |
