System Administration Guide: Devices and File Systems
ProcedureHow to Enable or Disable Read or Write Protection and a Password on Iomega Media
You can apply a password with a maximum of 32 characters for Iomega media that support this feature. You cannot set read protection or write protection without a password on Iomega media. In this situation, you are prompted to provide a password.
You receive a warning message if you attempt to apply a password on media that does not support this feature.
Steps
  1. Determine whether you want to enable or disable read protection or write protection and a password.
    1. Enable read protection or write protection.
      $ rmformat -W enable device-name
      Please enter password (32 chars maximum): xxx
      Please reenter password:
      $ rmformat -R enable device-name
    2. Disable read protection or write protection and remove the password.
      $ rmformat -W disable device-name
      $ rmformat -R disable device-name
  2. Verify whether the media's read protection or write protection is enabled or disabled.
    $ rmformat -p device-name
Example 3–6 Enabling or Disabling Read or Write Protection
This example shows how to enable write protection and set a password on a Zip drive.
$ rmformat -W enable /vol/dev/aliases/zip0
Please reenter password: xxx
This example shows how to disable write protection and remove the password on a Zip drive.
$ rmformat -W disable /vol/dev/aliases/zip0
This example shows how to enable read protection and set a password on a Zip drive.
rmformat -R enable /vol/dev/aliases/zip0
This example shows to disable read protection and remove the password on a Zip drive.
$ rmformat -R disable /vol/dev/aliases/zip0
