Java Dynamic Management Kit 5.1 Getting Started Guide
2.5.5 Cascading
Cascading is the term used to describe a hierarchy of agents, where management requests are passed from a master agent to one of its subagents. A master agent connects to other agents, possibly remotely, through their connector server components, much like a manager connects to an agent. In a set of cascading agents, all MBeans in a subagent are visible as if they are registered in their master agent. The master agent hides the physical location of subagents and provides client applications with a centralized access point.
In Java DMK 5.1, the cascading service is implemented over JMX Remote API connectors. The CascadingServiceMBean makes it possible to mount source MBean servers, that are possibly located in subagents, into a target MBean server, that is located in the master agent, in a manner that is somewhat analogous to a File System mount operation.
2.5.5.1 Object Names and Domain Paths
The Java DMK cascading API introduces the notion of a domain path. An ObjectName is thus decomposed into three parts, as follows.
domain-path/domain-base-name:key-property-list
The domain path is a hierarchical name similar to a File System path name, using the character `/' as a separator.
2.5.5.2 File System Analogy
The CascadingServiceMBean provided in the Java DMK 5.1 makes it possible to mount MBeans from a source MBean server under a target domain path in a target MBean server, in a similar way to a File System mount operation.
Although our API also allows you to implement different cascading schemes, we recommend that applications only implement those schemes that can be compared to a regular File System mount, as follows.
Our implementation does not enforce those rules, but applications which are concerned with naming consistency and coherency should make sure to respect them. See the package description in the API documentation for the com.sun.jdmk.remote.cascading package for details.
2.5.5.3 CascadingServiceMBean
The cascading service proposed in the com.sun.jdmk.remote.cascading package is based on a simple MBean class, the CascadingServiceMBean.
The default CascadingService implementation provided in the Java DMK 5.1 relies on proxy-based cascading and implements the mount operation by instantiating a ProxyCascadingAgent behind the scenes. Although the ProxyCascadingAgent offers a public API, you should not use it directly. Applications should use the CascadingServiceMBean instead.
CascadingServiceMBeans are also notification emitters, which emit notifications when mountpoints are unmounted, as a result of a an unmount operation, or because the underlying connection with the source MBean server has been closed or failed.
2.5.5.4 Cascading over Java DMK legacy connectors
There are two possibilities to implement cascading over Java DMK legacy connectors.
