Name | Synopsis | Description | Options | Operands | Examples | Exit Status | See Also
delete-system-property [--terse={true|false}][ --echo={true|false} ] [ --interactive={true|false} ] [ --host host] [--port port] [--secure| -s ] [ --user admin_user] [--passwordfile filename] [--help] [ --target target_name ] [property_name]
Shared or clustered server instances will often need to override attributes defined in their referenced configuration. Any configuration attribute in a server instance can be overridden through a system property of the corresponding name. This command deletes system properties of a domain, configuration, cluster, or server instance.
Indicates that any output data must be very concise, typically avoiding human-friendly sentences and favoring well-formatted data for consumption by a script. Default is false.
If set to true, the command-line statement is echoed on the standard output. Default is false.
If set to true (default), only the required password options are prompted.
The machine name where the domain administration server is running. The default value is localhost.
The HTTP port or HTTPS port for administration. This port is the port in the URL that you specify in your web browser to manage the domain, for example, http://localhost:4848.
The default port number for administration is 4848.
If set to true, uses SSL/TLS to communicate with the domain administration server.
The default is false.
The user name of the authorized administrative user of the domain administration server.
If you have authenticated to a domain by using the asadmin login command, you need not specify the --user option for subsequent operations on the domain.
Specifies the name, including the full path, of a file that contains the password entries in a specific format.
The entry for a password must have the AS_ADMIN_ prefix followed by the password name in uppercase letters. For example, to specify the password for the domain administration server, use an entry with the following format:
AS_ADMIN_PASSWORD=password
In this example, password is the actual administrator password.
The following other passwords can also be specified:
AS_ADMIN_MAPPEDPASSWORD
AS_ADMIN_USERPASSWORD
AS_ADMIN_ALIASPASSWORD
All remote commands must specify the administration password to authenticate to the domain administration server. The password can be specified by one of the following means:
Through the --passwordfile option
Through the asadmin login command
Interactively at the command prompt
The asadmin login command can be used only to specify the administration password. For other passwords that remote commands require, use the --passwordfile option or specify them at the command prompt.
After authenticating to a domain by using the asadmin login command, you need not specify the administration password through the --passwordfile option for subsequent operations on the domain. However, only the AS_ADMIN_PASSWORD option is not required. You still must provide the other passwords, for example, AS_ADMIN_USERPASSWORD, when required by individual commands, such as update-file-user.
For security reasons, a password that is specified as an environment variable is not read by the asadmin command.
The default value for AS_ADMIN_MASTERPASSWORD is changeit.
Displays the help text for the command.
Do not specify this option. This option is retained for compatibility with other releases. If you specify this option, a syntax error does not occur. Instead, the command runs successfully and the option is silently ignored.
asadmin> delete-system-property --user admin --passwordfile password.txt --host localhost --port 4848 --target mycluster http-listener-port Command delete-system-property executed successfully. |
